Monster MotorsportEM Tuning
Results 1 to 12 of 12
    alcoholic pervert
    Nov 2008
    Chalford - the Cotswolds.
    195
    Handbrake makes ABS and brake warning lights come on
    Chaps.
    Like it says. Only it only happens if the handbrake is used with the car facing uphill, like doing a hillstart.
    When I say ABS and brake warning lights I mean the little red ones in a circle, one says ABS the other has a exclaimation mark in a triangle.
    They go out and don't come back on when the key is removed from the ignition, until the next hillstart scenario.
    I changed the front pads and bled the fronts last week and everything feels fine under braking. Didn't touch the back at all.
    Anyone any thoughts?
    alcoholic pervert
    Nov 2008
    195
    bump
    Keeps doing it. Anyone had anything similar?
    Oct 2009
    Hull
    1,440
    check your brake fluid level!
    SmoothAssault's Avatar
    Will design for mods
    Dec 2007
    Cambridgeshire
    788
    I could be wrong, (not driven my car for a few months) but doesn't the red exclamation mark one always come on when the handbrake is applied? ABS light coming on is a strange one though.
    FOR SALE: Eibach Sportline Springs from B5 A4. £50 - PM for details.
    alcoholic pervert
    Nov 2008
    195
    It's full. The front pads were well worn when I replaced them so there was a lot of pushing the pistons back, hence the fluid was already maxing out. Then I bled it, topping up as needed.
    alcoholic pervert
    Nov 2008
    195
    Quote Originally Posted by SmoothAssault View Post
    I think there's a different one for when the handbrake is on. Something resembling brake shoes round a drum. And it goes off when the handbrake is off.
    Oct 2009
    Hull
    1,440
    seems a bit odd!
    I mentioned fluid as it only does it on a hill it could have been low fluid exposing the sensor
    I would say a scan is in order to see if anything is amiss
    alcoholic pervert
    Nov 2008
    195
    Quote Originally Posted by stu_m View Post
    seems a bit odd!
    Yeah - I see where you're going with that. It would make sense.
    I might change the rear pads. Maybe the problem will go away. Failing that, as you say, a scan it is.
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,475
    iv never known pads front or back trigger the ABS sensor
    they rears dont have a wear indicator either
    Oct 2009
    Hull
    1,440
    after reading this again I would check the ABS sensors one of them may have come loose and popping out on a hill then going back in??
    also do a scan before replacing anything
    stick your location in your profile so people know where you are someone close may be able to offer a scan
    I have full vcds if it helps
    alcoholic pervert
    Nov 2008
    195
    Thanks for the offer stu. Updated my profile and as you can see we're miles apart!
    I guess it's more than probable I knocked an ABS sensor when changing the pads. Not that I noticed them! Are they obvious?
    Oct 2009
    Hull
    1,440
    yup they arent far from the brakes have a look you will see them
  1. Replies: 5
    Last Post: 18th February 2013, 00:11
  2. ABS AND TRIANGLE WARNING LIGHTS
    By blanc in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th October 2011, 14:41
  3. ABS light and warning light comes on if parked still for a while
    By SuziA3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2011, 16:21
  4. Replies: 2
    Last Post: 2nd March 2011, 12:01
  5. Just bled the brake fluid and replaced...Brake warning lights!!
    By Fahim in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th December 2010, 01:05
