EM TuningAH Fabrications
    glenandem's Avatar
    Sep 2012
    manchester
    459
    driveshaft info needed!
    hi guys,does anyone have access to a vw part no database and can check if all fwd driveshafts are the same across the range from 1.9tdi to say v6, b6 and b7?
    need a set of driveshafts as i suspect theyre causing vibration and have slight play on the inner joints and theres plenty of 1.8t b7 on ebay!
    Jun 2012
    Teesside
    392
    Theyre not mate there are slight differences in them, i got sent the wrong one and fitted without checking part number, it went on but was shorter causing annoying noises etc on driving..
    Mods done: interior: Light to dark conversion, To Do: Carbon trim, carpet to be replaced, rear window retrofit. Exterior: Resprayed in Skoda's Rallye Green, 18" RS4 reps fitted, xenons, LED sidelights/NumberPlate lights, B Pillars wrapped in carbon. To Do: Lowering 35mm all round, tints, Tuning: Yet to do exhaust/remap/ egr delete etc..
  1. Crank - flywheel info needed
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 14th February 2007, 20:07
  2. A4 TDI INFO NEEDED
    By vw754 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th December 2006, 02:26
  3. What are your front wipers like? Info needed please!
    By Nessy in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th October 2006, 11:01
  4. revo info needed
    By a3kid in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th July 2005, 17:53
  5. A3 Sport info needed please
    By bendz in forum A3/S3 Forum (8L Chassis)
    Last Post: 10th April 2005, 10:37
