Chris NottEM Tuning
Thread: Fan problem.
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    637
    Fan problem.
    B6 A4 1.9 TDI
    Right, I have 2 fans at the front of the car. As I got home tonight, I tuned the air con off about 30sec before turning the engine off. Shortly after, I heard a fan in the engine bay winding down. Though it was unusual. Opened the door and turned on the ignition (not engine) and the fan came on for about 10 sec (the fan on the driver's side), then went off for 10 sec, then came on for 30 sec, then off for 5, back on for... I turned the ignition off after that. I assume it would just carry on like that.
    I've had a bit of a search and come up with the control module for the fan, but I'm not sure my symptoms fit the bill.
    I have a capacity prob with my air con if that is relevant - can't put speed higher than 4 or it just blows ambient air.
    Any ideas guys?
    EDIT: Just left the car for an hour and tried the ignition again & now the fan on the right is on permanently.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    dale86's Avatar
    Oct 2012
    355
    I had similar problem and it was due to car overheating but it wasnt showing on the temp guage as been over 90 must of been because the fan was doing its job anyway it was down to waterpump failure luckily caught it in time. This probably isnt whats wrong with yours but its worth a check as the waterpumps are prone to failure.
    benjie's Avatar
    Oct 2009
    637
    Thanks dale, further development...
    Just driven to work, fan on all the time and today the temp gauge in the dash in't registering... I'm not starting to think it's the coolant temperature sensor... which was replaced a month ago!... because the symptoms now match what happened last time that went. though I'll keep what you said in mind...
    May 2013
    39
    I have a similar sort of problem my fan comes on very randomly but doesn't stay on when ignition is off which sways me away from the module fault, anybody have any ideas on what it could be?
    Current Car :-
    2004 A3 8P1 2.0 FSi - Midnight Blue - 18" TTRS Wheels - 40mm Rokkor Springs - K & N Induction -
    Previous :-
    Mk1 Seat Leon 1.9 TDI
    MK4 Golf 1.6
  1. 2.0 tdi fan problem HELP
    By Lex in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd May 2008, 23:00
  2. Fan Problem
    By vegas in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd September 2007, 02:48
  3. Fan problems
    By starski4578 in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2007, 17:16
  4. Internal heating/cooling fan problem?
    By jakeriddler in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st November 2006, 20:04
  5. Internal heating/cooling fan problem?
    By jakeriddler in forum General Technical / How To
    Last Post: 21st November 2006, 00:00
