Sky InsuranceVolks Autos
Results 1 to 8 of 8
    Jamie1985's Avatar
    Feb 2012
    Surrey
    67
    Replace Bonnet Lever (footwell)
    Hi all have been away from the site for a while car has been garaged for a fair time,
    Anyways got it out today to service before using fluids, oil etc and the bonnet release lever in the drivers footwell snapped, ive managed to get the bonnet open by removing front bumper!!!
    My question is how hard is it to replace the lever inside the footwell and also would i have to just do that or would i have to replace the whole cable and the latch under the bonnet?
    Regards
    Jamie
    Mar 2013
    Near Oxford
    405
    Very easy just replace the latch.
    Jamie1985's Avatar
    Feb 2012
    Surrey
    67
    Quote Originally Posted by madmike01uk View Post
    Is it as easy as that does it clip on or is it screwed together?
    Away from home at the moment so cant look
    Mar 2013
    Near Oxford
    405
    Just remove the lower trim panel the it unscrews out. You need a torx bit to remove the lever.
    Dubbers1's Avatar
    Top Gear
    Jul 2011
    Bedfordshire
    228
    I had to replace mine when i got my car, its a bit fiddly but not a difficult job
    Audi A4 1.8T S-Line Quattro (190) '04
    VCDS HEX-USB+CAN
    alcoholic pervert
    Nov 2008
    Chalford - the Cotswolds.
    195
    Just reviving this, with an extra question: can it be changed while the bonnet is stuck shut? Or does the bonnet need to be opened by some other means?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,573
    You should be able to change it fine as the is no tension on the cable until it is pulled
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    alcoholic pervert
    Nov 2008
    195
    Quote Originally Posted by Mike.M View Post
    Thanks man
  1. Looking for a replacement bonnet to buy
    By AudiMafia in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2012, 10:35
  2. Replaced wiper linkage, now water in drivers footwell
    By funkyspider in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st November 2010, 23:11
  3. DSG gear knob\lever replacement?
    By Wes G in forum A3/S3/Sportback (8P Chassis)
    Last Post: 10th April 2008, 13:30
  4. Gear Lever replacement gaiter
    By Sand in forum A3/S3/Sportback (8P Chassis)
    Last Post: 19th March 2008, 20:51
  5. Where's the lever for the bonnet?!
    By KARL in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th February 2008, 15:28
