Volks AutosMonster Motorsport
    Jun 2013
    Ireland
    Remote locking trouble
    So I am having some trouble with my car it is a 02 Audi A4 tdi, trouble is when I bought it the earth wire the goes from door wiring into the car was broke, so fixed that by soldering it, everything works fine accept when the passenger door is open it shows on the cluster display as the drivers door is open. When the drivers door is open nothing happens no display, no interior light nothing.
    The remote's 2 which are coded and have good batteries wont unlock the car or lock the car have to open the car manually with the key in the door then open the other 3 doors by the door lock switch on the drivers door.
    I have scanded with vcds and got the following codes
    Address 46: Central Conv. Labels: 8E0-959-433-MIN.lbl
    Control Module Part Number: 8E0 959 433 AJ
    Component and/or Version: Komfortgerát T9F 0619
    Software Coding: 06730
    Work Shop Code: WSC 00000
    Additional Info: 8E2959802B Tõrsteuer.FS BRM 4.11
    Additional Info: 8E2959801B Tõrsteuer.BF BRM 4.11
    VCID: 79F39C4063C24D6
    12 Faults Found:
    01336 - Data Bus for Comfort System
    80-00 - Single-Wire Operation
    01134 - Alarm Horn (H12)
    49-00 - No Communications
    01561 - Left Rear Door
    59-10 - Can't Unlock - Intermittent
    61-00 - Won't De-Safe
    01562 - Right Rear Door
    59-00 - Can't Unlock
    00956 - Key 2
    35-00 - -
    01331 - Door Control Module; Driver Side (J386)
    80-10 - Single-Wire Operation - Intermittent
    01705 - Selection Switch for Mirror-Adjust (E48)
    27-10 - Implausible Signal - Intermittent
    01559 - Drivers Door
    37-00 - Faulty
    01332 - Door Control Module; Passenger Side (J387)
    Address 03: ABS Brakes Labels: 8E0-614-517.lbl
    Control Module Part Number: 8E0 614 517
    Component and/or Version: ABS/ESP front 1726
    Software Coding: 04255
    Work Shop Code: WSC 06435
    VCID: E5CB40307F7A596
    1 Fault Found:
    01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
    35-00 - -
    Can anyone shed some light on this, do I have faulty door latch?
    I also checked the passenger side floor for dampness and it is dry no broken wires either
    Oct 2009
    Hull
    1,434
    check the rest of the wiring it sounds like you still have a break somewhere
    also pull the plug and check the pins
    Jun 2013
    Ireland
    Quote Originally Posted by stu_m View Post
    I have checked for continuity in all the wiring in the door all seems good, and pins seem good also I will get electrical contact spray tomorrow and clean and recheck.
    Is it possible to be the door lock itself?
    thanks
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,988
    sometimes the continuity check is ok
    but there can still be a break still
  1. Arrgghhhh Boot lock trouble
    By Backdrifts in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd January 2007, 17:47
  2. Blooming remote locking
    By ajmackie in forum A4/S4 forum(B5 Chassis)
    Last Post: 5th March 2005, 01:58
  3. A4 Remote locking
    By imported_b4rkie in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 10th September 2004, 18:37
  4. Help with vagparts remote locking kit?
    By technics100 in forum A4/S4 forum(B5 Chassis)
    Last Post: 27th July 2004, 09:00
  5. REMOTE LOCKING KIT
    By wezhaz in forum A3/S3 Forum (8L Chassis)
    Last Post: 29th March 2003, 17:16
