EM TuningChris Nott
    Leaky Lloyd's Avatar
    Apr 2010
    280
    electric window problem.
    so I just purchased a new electric window kit to replace the damaged one in my drivers door !
    after a long and daunting process its finally in !
    couple of slight problem,
    1, you have to constantly leave your finger on the button to get the window from top to bottom or vice versa where as on the passenger if you depress the button twice it rolls all the way down to the bottom,
    im pretty sure the drivers side use to do this,
    2, when winding the window up, if you leave your finger on the button right to the top the window automatically winds back down perhaps 4 inches, every single time it does this unless you time it to perfection as it closes fully !
    any ideas why folks ?
    thanks in advance !
    BRILLO's Avatar
    Sep 2011
    Juniper Green, Edinburgh, United Kingdom, United Kingdom
    135
    Hold button all the way down then all the way up while keeping finger on button. Repeat process twice and this should reset it.
    Apr 2010
    280
    thanks bud,, I'll try that !
    cjsuk's Avatar
    Feb 2012
    Leeds
    554
    Quote Originally Posted by BRILLO View Post
    +1
    Ill try stuff out! If you never try and never fail, you will never know and never learn.
    Apr 2010
    280
    sorted the 2nd problem but the 1st problem is still there !
    Greeny233's Avatar
    Mar 2011
    Leuchars
    550
    Follow Greeny233 On Twitter
    I think to fix the first problem you need to put all windows all the way down then all the way up together. I had the same problem when I did mine and I think this fixed mine.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
  1. Electric Window Problem
    By madmonzsta in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th May 2007, 18:39
  2. electric window problem :(
    By skanky in forum A3/S3 Forum (8L Chassis)
    Last Post: 25th September 2006, 09:51
  3. S3 Electric Window Problem :(
    By jonS3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th September 2006, 22:51
  4. central locking and electric window problem
    By cliffyeee in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th August 2006, 10:06
  5. A4 1.9 TDi B6 - Electric Window problem
    By Neil_S in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2006, 22:46
