Sky InsuranceEM Tuning
Results 1 to 12 of 12
    dale86's Avatar
    Oct 2012
    307
    tyre stretch on a quattro
    Now then peeps here it goes itl be a proper mind boggler so hope u can keep track lol. Right then I want to fit my nicely refurbed b5 s4:caliper set up on my b6 quattro BUT here are the issues I need to space my rims out 12mm to make et35 but to do this I also need to run stretch as im on 19s and tucking tire up front my arch is comfortably half way down the tyre and does not do full lock anymore. Are you still with me lol so I am willing to replace my front tyres which aint nowt wrong with for some strech but Im unsure on what kind of strech people run and also if I go strech up front and not rear (for now until I can afford another pair of tyres) will I affect the rolling radius enough to damage the quattro system. Hmm I told you it was a right mare of a situation lol thanks in advance.
    dale86's Avatar
    Oct 2012
    307
    Any help on this would be appreciated ive never ran stretch but im assuming that stretching tyres will lower the profile of a tyre !!!!!!
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    535
    The rolling radius will still be the same, you will be pulling the side walls into the middle while maintaining the rolling radius.
    1.9 avf 6 speed. Bv43 turbo. Swifttuning custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,712
    Quote Originally Posted by deano1978 View Post
    Surely by running the sidewall stretched (ie at an angle) the profile will appear lower than if you ran that same tyre normally, (ie with the sidewall perpendicular to the rim)? And the effect of that would be to reduce the rolling radius.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    535
    yeah but the rolling radius in the middle of tyre is still the same. But if you are rolling on the oustide of the tyres then yes the radius wld differ
    dale86's Avatar
    Oct 2012
    307
    Im kind of swaying towards what quattrojames said if your pulling the sidewalls out over its going to lower the centre of the tyre isn't it hmmm. This is a right ball ache just for a set of callipers lol. I appreciate all info guys so keep it coming I'd rather be sure than trash my diff and box .
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,100
    If in doubt use a tyre calculator, stretch doesn't usually make much difference to rolling radius then again depends how extreme it is
    Online Wheel & Tyre Fitment calculator. Offset, Tyre stretch and Rolling Radius calculator
    Cornering will probably be effected too but the stance should look good
    Greeny233's Avatar
    Mar 2011
    Leuchars
    550
    Follow Greeny233 On Twitter
    If it helps I run 235/35-19's all round on my staggered BBS LM replicas on my Quattro and have been for the last 12 months with no issues with the drive train.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    dale86's Avatar
    Oct 2012
    307
    Thats what I run at the moment but et 45 and 8.5j I think but if I go around a corner on not even full lock I get tyre into arch scenario what about you mate.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,068
    Dont mean to throw a spanner in the works here, but I was advised that the B5 S4 Lucas brakes arent much of an upgrade.
    I was going to do this - but went along with B6 S4 brakes in the end - they are single pot brakes and 345mm discs, the difference was night and day in comparison to the standard 312mm setup - they bolt right on too with no spacers needed.
    dale86's Avatar
    Oct 2012
    307
    Yeah ive heard this about the b5 s4 stoppers but its not so much the stopping im after but looks as its only a humble diesel with a remap and I cant really turn back now as theyve been fully powdercoated and rebuilt lol.
    May 2013
    21
    Run 215/40 or 205/40 if you need a lot of stretch.
  1. Tyre Speed Rating On Quattros Massively Conservative ?
    By rt05492 in forum A4/S4 forum(B5 Chassis)
    Last Post: 2nd October 2010, 20:25
  2. what new tyres for my a4 quattro 2.5 v6 tdi ?? should i get..... ???
    By subaru swift in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th September 2010, 19:29
  3. wdo you think these will fit my allroad ..... with a bit of tyre stretch!!
    By driftanimal in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 25th May 2010, 11:52
  4. Porsche Cup tyre sizing on a Quattro, HELP
    By Adamh_A3Q in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2009, 18:28
  5. Tyre wear & Alignment - A4 Quattro
    By JohnboyC in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th April 2009, 05:55
