Badger5EM Tuning
Results 1 to 11 of 11
Like Tree2Likes
  • 2 Post By mattyb6
Thread: Upper shocker bolts
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Upper shocker bolts
    When I had my coilovers fitted, the rear shock absorber bolts went in fine. But the one of the top ones snapped inside the hole.
    Just recently this has caused a really bad knocking where the top mount is spinning round and hitting the inner wheel arch.
    ha anyone had one of these bolts snap and of so how did there fix it?
    i think il have to drill it out and re tap the hole
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Sounds a bit dangerous, having the top mount only secured with one bolt!?!? Fair bit of movement there!
    Defo a big enough diameter on the bolt to get an Ezy-Out kit in there...saves re-tapping then. Part number for the bolt is 907 583 01, £1.17 each +VAT.
    A4 Avant 1.9 TDi Sport GmbH
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Its fairly secure on all fairness but it does new doing.
    What is an Ezy out kit?
    And do you think it will be pain in the backside?
    Il pop to the dealers and get a new bolt.
    Sep 2012
    Swindon
    371
    Ez-out allows you to drill a hole in the bolt then you drive the ez-out bit into the hole. I cuts in, a bit like a drill bit and drives in the opposite way to the bolt thread so when it bites it unscrews the damaged bolt. Should be relatively straight forward if the bolt isn't corroded.
    8 Piece Broken Damaged Screw Stud Bolt Remover Extractor Easy Out Outs | eBay
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Canny bit if of kit that like mate, and for £8 is worth it for the future.
    the bolt is fine I believe.
    Well it's getting full new arms this weekend and rs4 ARB so il get this done too.
    cheers fella
    Sep 2012
    Swindon
    371
    Won't be the best out there but should suffice for the home mechanic.
    Good mod the RS4 ARB. Stops my Avant cornering like a canal barge!
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Hahaha.
    mines getting some tlc this weekend. Feeling sorry for itself.
    tbh I either do 17mile trip on a motorway twice a day. So rs4 ARB is pointless. BUT I can go a different way, through country lanes and old pit villages. Which as you probably know can be a bit fun to drive (told our lass I need it though)
    swarcup and Audi Doodah like this.
    swarcup's Avatar
    Breakout Champion
    Sep 2009
    beverley,East yorkshire
    1,270
    go for it, when I did mine it was like night and day. love it
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Prices are £100 plus brackets etc
    plus £300 plus vat for control arms.
    Going to be an expensive day tomorrow.
    Andie0's Avatar
    Aug 2012
    487
    You can put a nut over the top weld in the centre of it to the broken bolt then undo with a socket bit over top once cold
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    453
    Quote Originally Posted by Andie0 View Post
    Never thought of that. Il take the shocker off and have a good look
  1. Joined the pita upper control arm bolt!
    By VagCabby in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2013, 23:34
  2. Rounded one of my locking wheel bolts off
    By Markb in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th June 2004, 14:57
  3. Question with lug bolts with Mille Miglia Wheels
    By Kasper in forum A4/S4 forum(B5 Chassis)
    Last Post: 16th February 2004, 19:13
  4. Locking Wheel Bolts
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th January 2004, 12:42
  5. S3 upper stress bar on to an A3?
    By Drill in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2003, 10:00
