Volks AutosAH Fabrications
Results 1 to 8 of 8
Thread: VCDS experts
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    VCDS experts
    Calling all VCDS Guru's.
    Is it possible to disable the front sidelight bulb out warning but keep the bulb failure system intact for the rest of the bulbs?
    2004 A4 Sport Cabriolet 3.0
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Coding out bulbs would be ridiculous so, why???
    A4 Avant 1.9 TDi Sport GmbH
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    It's not ridiculous if you don't need them anymore ;-)
    DRL's and new projectors fitted
    Oct 2009
    Hull
    1,440
    Put resistors in line so the car thinks it has bulbs?
    Sep 2012
    Swindon
    371
    Was gonna suggest the same!
    vivalacoulter's Avatar
    May 2013
    S. Wales
    194
    Follow vivalacoulter On Twitter Add vivalacoulter on Facebook Visit vivalacoulter's Instagram Channel
    Don't forget resistors generate heat depending how long they're used!
    Rudedaubin's Avatar
    Oct 2011
    South Yorkshire
    70
    I did think about resistors but then I'd have to find some way to mount/protect them , which isn't a problem , but if coding is possible surely it'd be the better solution.
    Sep 2012
    Swindon
    371
    Quote Originally Posted by vivalacoulter View Post
    Resistors generate heat depending on how much current flows through them...much like a bulb. Time is not really a factor as current flows in an instant. If heat is an issue a bigger surface area will help to dissipate excess heat.
  1. Vcds expert required
    By Chillout in forum A3/S3/Sportback (8P Chassis)
    Last Post: 13th April 2013, 12:35
  2. VCDS Expert required
    By vroomtshh in forum VCDS (formerly VAG-COM) forum
    Last Post: 22nd October 2012, 22:29
  3. Key Coding with VCDS Report , Expert Required!!
    By Blacky165 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 28th September 2012, 15:46
  4. Help needed - Vag-com owners/experts?
    By tim99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th May 2004, 18:15
  5. Any terminal server experts??
    By Drystone in forum General Chat
    Last Post: 12th March 2003, 16:55
