JMB RetrofitsEM Tuning
    Oct 2012
    tamworth staffs
    19
    manifold chatter on s4
    i sometimes get a chattering from my manifold its a v8 2003 my i thought it was a tappet gone but when i put pressure on the rod from the vacuum unit to the manifold adjuster it stops ???? any help would be appreciated
    i have seen on a usa forum of an ecu upgrade ??
    when driving it seems to go flat when accelerating and that causes the diagnostic to throw misfire faults ?
    Dec 2006
    barnsley
    1,016
    your on about the intake manifold butterflies
    these can sometimes stick open or not open above 5000rpm losing you around 60bhp
    the way to check this is
    remove the front top engine cover
    just behind the front panel right in the middle of the engine you should see a black lever which has a spring on it
    when this is working correctly it should actuate at 5000rpm and open the secondary butterflies to allow more air into the engine
    if its isnt working or its sticking it can often cause problems and cel codes
    warm the engine up and rev the engine past 5000rpm
    the lever has two positions fully open or fully closed and shouldnt be anything in between
    if it is and you can move the lever by hand and the noise stops you can try to take it apart and clean it with the aid of a very soft wire brush (be warned if you lose any parts or break anything you will need a new inlet manifold as the part isnt sold seperate)
    i have seen nothing as regards an ecu upgrade im afraid
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
  1. URGENT ADVICE - MANIFOLD RHD??
    By StevieBogan in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th January 2005, 19:52
  2. Manifold Boost Pressure Switch
    By mtsakmakis in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th December 2004, 20:30
  3. Dahlback Racing Inlet Manifold
    By RichA3Turbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 4th October 2004, 20:14
  4. Garrett manifold
    By saldale in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th April 2003, 13:38
  5. Polished inlet manifold
    By ooooaudi in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th March 2003, 01:00
