JMB RetrofitsAH Fabrications
Results 1 to 12 of 12
Thread: Tyre help
    czm
    Feb 2013
    215
    Tyre help
    HHi have just got a set of RS4 5 spoke alloys for my 1.8t Avant
    I was going for standard 235/40 18 but I have been offered a pair of mint 235/35 18.
    could/should I run these on the front with the 235/40 on the rear?
    other than the slight speedo change is there any other issue to prevent this set up.
    2004 BEX 1.8T Silver Avant - RTECH Stage 1 Remap - 211Bhp/236ft Torque
    TEIN Super Street Coilovers - BlueFlame Catback with 4'' Slashed/Rolled Tips
    Pipercross AirFilter- RS6 18'' OEM's - 225.35.15 Falken 452
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    You running fwd or quattro?
    czm
    Feb 2013
    215
    Fwd m8
    Mar 2008
    Dorset
    13,856
    It'll be fine then
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    May look a little odd though being a lower profile on the front and perhaps a tad harsher over bumps.
    Other than that, will be fine.
    czm
    Feb 2013
    215
    Quote Originally Posted by krisavant View Post
    Do you think
    My previous 330 BMW touring had 35's front and 40's rear and it did not look add at all.
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,333
    Should be fine, ran a similar setup on 19's with no issues (and no quattro malarkey haha). Eventually bit the bullet and went 35 all round, prefer same at each corner. Just remember tyres are economy, speed, breaking, handeling, etc... also money though.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,563
    The only issues I can see is that you speedo will not be accurate as you are reducing the rolling radius of the wheels and the ride may be marginally harder due to the reduced side wall
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Jul 2012
    432
    Quote Originally Posted by czm View Post
    Do you think
    Ok fair enough but with the tyres being the same width the 5% difference must have been noticeable side on?
    Jun 2011
    213
    bmw's usually have 40 front and 35 rear and run a staggered set up on most e46 running 18's. in your case with the audi i can't see it would hurt and would bearly be noticable if you were to run the set up you talk of
    Apr 2012
    lincs
    210
    It's still normal to have the wheel centres level and all the tyres the same rolling radius (and circumference).
    An M3 running 225/40's and 255/35's 18" staggered has 1mm different rolling radii, although the tyres are 30mm different in width. The tyre's sidewall height will be near as exactly the same.
    I'm not saying it's a great difference but if you've gone to the trouble of designing and making a car with near 50/50 weight distribution and equal corner weighting you're going to specify the tyres so it runs level.
    The sidewalls of the 35 tyres in the OP's post are 9mm shallower and, if, on the speedo axle will be out by about 5mph.
    A4 2.5 tdi Q sport '02 AKE, "minor modder", 18x8's S4 Avus , Zender Monza's 18x8.5's, aero wipes, interior trim, dis and cruise, real s4 mirror caps, rns-e led, dble din, VCDS owner-learner - GMBH next
    Nov 2012
    Warwick
    41
    BMW 330 have different width tyres front and rear. The 35 is a percentage of the tyre width in height.
    Also how about the ABS?
    It will see different wheel speeds so may make the ABS play up.
    Tom.
  1. Tyre Help!!!
    By cabby86 in forum A3/S3 Forum (8L Chassis)
    Last Post: 14th January 2010, 22:14
  2. hi every1! new tyres... help!
    By ian 06 A3 2.0 tdi s line in forum The Welcome Section
    Last Post: 2nd June 2009, 16:04
  3. tyre help
    By jcb in forum A4/S4 forum(B5 Chassis)
    Last Post: 9th October 2008, 13:39
  4. Tyre help!!!!!!!
    By phantom in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2008, 14:07
  5. Quick tyre help needed !
    By Amchlolor in forum A3/S3/Sportback (8P Chassis)
    Last Post: 3rd April 2007, 10:56
