hi ugys after replacing the little coolant pipe that runs round the back of the engine today i noticed that when i removed the turbo pipes they had a fair bit of oil in them and i also noticed it in the vac pipes and oil around the solenoids down behind the headlight on the drivers side?
ive blocked the egr off so wondered is there a vac pump or something causing oil to get into these pipes or could it be a sign of turbo issues? its boosting great and only a small puff of diesel smoke out the rear when accelerating which im presuming could be due to the slightly remapped engine?
