EM TuningChris Nott
Results 1 to 31 of 31
Like Tree1Likes
  • 1 Post By Audi Doodah
Thread: Symphony stereo
    Oct 2010
    346
    Symphony stereo
    I got these 4 keys off eBay and for the life me I cannot remove this good damn stereo. It's the double din with cd changer built in. Any advice? Or are the keys just crap?
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    So that's why you want the glovebox out!
    A4 Avant 1.9 TDi Sport GmbH
    Oct 2010
    346
    Cos once I got stereo out I was gonna run iPod wires into glove box for new stereo like I did with the golf.
    Oct 2010
    346
    No that not why. Lol
    Sep 2012
    Swindon
    371
    I was thinking you can push on the back of the headunit when the glovebox is out...
    Oct 2010
    346
    Really ok
    Sep 2012
    Swindon
    371
    Unless you have hands like shovels, you should be able to apply some force to the back of it. Just make sure the keys make a positive click when inserted IIRC
    Oct 2010
    346
    Ok glove box out. Phase 2
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,991
    get better keys ?
    Oct 2010
    346
    Romeo done!! It's out.
    Oct 2010
    346
    Phase 3. No power to new hu. Is the wiring different ie power and ground. Like the golf?
    bez101's Avatar
    Jul 2008
    7,991
    what HU are you fitting ?
    Oct 2010
    346
    Pioneer avh p4200 dvd
    bez101's Avatar
    Jul 2008
    7,991
    did you get the correct wireing ?
    you also have to run a igg feed to the new HU
    Oct 2010
    346
    Ignition feed? Wtf this is turning into a joke?
    Oct 2010
    346
    Oh I see only 2 connectors line up.
    Oct 2010
    346
    Any wiring diagrams?
    Oct 2010
    346
    I can pull the male connectors out but I don't know the wires are the Audi???
    Oct 2010
    346
    Anyone?!?
    Sep 2012
    Swindon
    371
    I'd suggest getting a harness adapter Audi Installation Adaptors From Car Audio Direct . Expensive if you have a Bose system.
    Oct 2010
    346
    How would I know if mine is Bose?
    Oct 2010
    346
    How do I get I to work with constant power on?
    Sep 2012
    Swindon
    371
    Quote Originally Posted by vwgtiking View Post
    Your door speakers will have the Bose logo and the headunit says Bose when it first powers on.
    Sep 2012
    Swindon
    371
    Look what I found with a quick SEARCH
    quattrojames likes this.
    Sep 2012
    Swindon
    371
    And if all you wanted was an ipod hookup, these are plug and play with factory headunits
    Oct 2010
    346
    Ive connected the yellow and red wires together on headunit and still. I power
  28. #27
    Oct 2010
    346
    Still no pwr*
  29. #28
    Sep 2012
    Swindon
    371
    Do you have a multimeter? Test for correct voltage on the wires? Has the fuse blown on the car? Has the fuse blown on the headunit? Have you ever seen your new headunit working?
  30. #29
    Oct 2010
    346
    Found the issue. The acc cable on the headunit has a resistor and this didn't give the headunit enough power to start up. Swapped it over and it works. Next job is to wire in an ignition wire and get the rear speakers working.
  31. #30
    Oct 2010
    346
    With regards to this the 3rd connector the one furthest to the left. What are these connections for? Do I need the com and arrow with a dot middle???
  32. #31
    Sep 2012
    Swindon
    371
    You rear speakers aren't working because they're driven by an amp in the boot, via the line outs, I believe.
    There is plenty of info out there as you're not the first to fit an aftermarket headunit.
    Rear speakers not working
    PC9-404 connected... rear speakers still not working.
    How to install an aftermarket radio without a wiring harness - AudiWorld Forums
    http://www.audi-sport.net/vb/a3-s3-sportback-8p-chassis/76733-help-aftermarket-stereo-replace-concert.html
    It took me 2 minutes to find the links. I would suggest you spend some time reading up before continuing.
  1. Stumped!! Changing A3 (8L) Bose Symphony stereo
    By bernie in forum In-Car Entertainment
    Last Post: 16th October 2010, 00:49
  2. Symphony stereo switching itself off!
    By SMc in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th March 2010, 10:48
  3. Symphony Stereo plus Ipod
    By DaveA3-TDI in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th October 2009, 17:31
  4. symphony stereo - cd text??
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th December 2006, 17:51
  5. removing symphony stereo
    Last Post: 15th December 2006, 15:59
