AH FabricationsSky Insurance
Results 1 to 12 of 12
    Jun 2013
    7
    A4 Cab B6 windscreen nightmare!!
    Hi Eeryone first post and sorry to say a problem.
    Wife had a new screen fitted over a year ago and afterwards leaked like hell and played havok with all the elctrics resulting in 5 AA calls outs; not good!
    She got another crack a few months ago when a piece off a lorry smacked into her screen on the motorway. Called insurance, they set up with AA windscreens and they have been nothing but useless taking over three weeks to get to us. Went to her work, only after an hour called my wife to say he couldnt fit the new screen because the previous firm had rounded off the bolts! he has loosened off the ally strips and thats it - could he thinking the rivets under the strips are bolts and has not a clue, or are there bolts visable?
    He told my wife to go to Audi, get them drilled out and then call them to arrange fitment again.
    Is this true? or does he not know the first thing about her 2004 A4 Cab? Before I go into savage mode and make a fool of myself can someone enlighten us as to wether he is correct.
    Many thanks
    Kozzi
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    You do have to drill out the rivets, then replace with new ones on reassembly.
    I'm not sure what bolts might be involved, I've only replaced one of the aluminium sides on my Cab.. I'll check my workshop manual.
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Mar 2008
    1,052
    the trim is riveted and bolted on from inside the car you have to drop off the plastic trim where the sunvisors are then you will see the bolts .. if your bolts are no good you can always bold the trim inplace
    Jun 2013
    7
    Thanks Jason, I would assume u have to take the trims off to even begin with the windscreen removal? No drill in tool kit means no rivets removed
    Jun 2013
    7
    VR6Gordy can you see the bolts if the rivets are still in place?
    Mar 2008
    1,052
    drop the sunvisor trim off and you will see the bolts ..trim at top of windscreen the your light is
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    Both side trims come off, then the top trim before you can remove the screen and bond a new one in place.
    There are a couple of bolts at the top of the side trims that connect to the top trim, these are accessed by removing the interior headlining trim.
    I lost the nut a couple of times and had to retrieve with a magnet as I was worried it would rattle about.
    Previous Audis:
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Jun 2013
    7
    Those might be the ones he said were rounded off
    Jun 2013
    7
    Would they be easy to drill out if needed?
    Mar 2008
    1,052
    the bolts are bonded on top the ally trim doubt they are rounded off as they would break off before they rounded off
    Jun 2013
    7
    They guy said he could not carry on as the bolts were rounded off!!
    This is weird!!
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Check it out yourself mate as Jason and Gordy have said, if all looks to be as it should (how these guys are saying it should be) then I'd get on the blower to your insurance company and tell them you want someone to come out and do the windscreen who actually knows what they're talking about! And pronto! 3 weeks to come out to you is a joke!
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
  1. 2003 A4 Cab, windscreen blower air-flow problem
    By dhillon884 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th February 2014, 12:59
  2. A4 cab alloy windscreen surround
    By geeza in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 8th August 2013, 18:23
  3. A5 Cab - S Line windscreen trim
    By steffyo in forum A5/S5/RS5 Forum
    Last Post: 26th July 2010, 10:07
  4. A4 Cab Windscreen Surround
    By niftyandy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 26th February 2010, 11:01
  5. A4 cab windscreen trim
    By PMJ in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th February 2010, 23:46
