EM TuningChris Nott
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    631
    different graded oil,in summer
    Does anyone change there grade of oil in the summer?
    Notice i get upto temp very quickly.
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Oct 2012
    434
    I wouldn't bother over here, i run 5/40 all year no issues in summer or winter
    Jun 2013
    Southampton
    100
    I assume your dash in your A4 will be the same as mine thus when you're saying up to temp you are actually referring to the temperature of your engine / coolant. Just because that is up to temperature doesn't mean that your oil will be! My last car had an oil temp gauge too and the engine itself was always up to temperature way before the oil was at it's optimum running temperature.
  1. what grade oil for a A3 tsfi 1.8t petrol 59 plate
    By Quattro Singh in forum A3/S3/Sportback (8P Chassis)
    Last Post: 17th April 2013, 12:46
  2. Thicker grade oil for multitronic??
    By AudiiduA in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2010, 15:24
  3. Just a quickie! S3 what grade oil???
    By S3 Eddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th May 2010, 17:27
  4. Difference with Oils?
    By wilko in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th November 2005, 21:10
  5. Would wrong oil make a difference to performance?
    By wigginer in forum General Technical / How To
    Last Post: 11th January 2005, 19:12
