    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    Battery removal FFS Urgent help please
    How do you remove the battery, ive been f**king around trying to remove the hex clamp on the engine side of battery ,ive unclipped the side support but I cannot get a poxy allen key or allen socket on it, im f**king fuming , there must be an easier way or am I missing the point ,
    Feb 2011
    Worcester, Worcestershire, United Kingdom
    46
    1/4 drive socket set 5 or 6 mm hex bit it's a tight fit but possible or remove the brace think its 2 17 mm bolts either end ! Good luck :-)
    May 2013
    redditch b98
    359
    Add bradh on Facebook
    socket exstention is needed nice a thin one undo the brace on pass side should give u enough room to bump battery out this way
    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    Moved brace and managed to get extension bar on , job done, uprated battery to a 800 ccA and 85Ah (3.0tdi spec) fron 480 ccA and 62Ah what a massive difference when car turns over on start up!!!!
  1. PB team need urgent help - please read!!!
    By WX51TXR in forum Detailing
    Last Post: 18th July 2007, 15:19
  2. Urgent Help Please
    By dentsy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 25th May 2007, 15:52
  3. URGENT HELP PLEASE - CAR IN BITS AND GETTING DARK!!
    By Platinum70 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2006, 22:13
  4. URGENT HELP please
    By S3_MCD in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th May 2006, 22:42
  5. URGENT Help Please
    By [Dave B] in forum A3/S3 Forum (8L Chassis)
    Last Post: 5th November 2003, 17:06
