Badger5AH Fabrications
Results 1 to 20 of 20
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    626
    coilovers knocking noise. fix, may be
    Ok i got my coilovers installed a while back now but b4 that my ride was nice and SILENT.
    Once installed i noticed a knocking noise and knew it was coilover related. Just been driving day to day and trying to ignore it. Read loads of threads,people changing,engine mounts,top mounts,bushes,suspensions arms all to no avail.
    But i did see that someone mentioned drive shafts. I went and checked for play and i reckon thats the cause. There was around 2mm each of play in both drive shafts and the noise it made of tapping was very familiar to whats occuring while driving.
    So if you have coilovers check or confirm that theres play in there (left to right)
    I dont know if its the norm to have play in the drive shafts, (2mm) id b glad to find out its not the norm and ive found the dreaded knocking noise!
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Andie0's Avatar
    Aug 2012
    487
    Mine knocks when i have my coilys set to hard and gets quieter and quieter the softer i set them! On full soft no knocking....weirdddd
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    626
    Maybe with the stiffness to softness as its being adjusted it changes the travel lenght
    So as its soft the suspensions near it original height,nice n tight with drive shaft
    Stiff is lowered so mgt create that little gap with the drive shafts beings its changed height? Which creates the knocking noise
    Just another thought.
    Andie0's Avatar
    Aug 2012
    487
    We must get to the answer... I put up with the knock as like it stiff
    spartacus 68's Avatar
    Dec 2008
    Aberdeenshire
    254
    Quote Originally Posted by Andie0 View Post
    Worn suspension drop link and ARB bush? Both inexpensive and easy to replace.
    2002 A2 1.4 TDi SE (125k)
    2001 A4 2.5 TDi Avant Quattro Sport (155k)
    1995 80 TDi Avant SE (175k) Sold
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,317
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    If there isn't any play in the drop link and arb bush then it's not, I got this and it's passenger and guess what I've know for months it's my driveshaft had the driveshaft end rebuilt once but now got play again need to just get a new one
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,152
    Mine were fitted about 3 months ago, dont get any knocking - I replaced all front suspension arms & ARB bushes at the same time.
    I do occcasionally get the odd spring movement noise - which im guessing is the sound of the helper spring moving against the main spring, only happens every now and again.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    666markyboy's Avatar
    Mar 2008
    Oldham, Manchester
    1,109
    Pretty sure the driveshafts should have some in and out movement... the shaft is on splines and it needs a small amount of movement as it changes length ever so slightly as the suspension moves up and down... all that tends to happen with drive shafts is the outer CV joint will fail... this gives a clicking sound as you move forwards with full lock on the steering
    1999 A3 Quattro 1.8T Pics >>HERE
    2002 A4 Avant quattro 1.9 TDi
    Aug 2009
    north east U.K
    1,317
    You should get a little in out movement
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    626
    Quote Originally Posted by spartacus 68 View Post
    Yep. Replaced all of that and all arms. No difference. Still there. Bummer!
    Andie0's Avatar
    Aug 2012
    487
    same... Replaced everything except for upper control arms as cant be assed with pinch bolt
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    626
    So maybe cv joints? What do you guys reccomend? New cv units?New shafts, reconditioned?Is it as simple as taking old out and putting new in?Reas about drive shafts need balancing?Didnt change my top mounts as garage said there ok,and the knocking is sounding further down towards wheels.
    Aug 2009
    north east U.K
    1,317
    ive changed everything mentioned even cv' hub' bearings for all new genuine only thing left is the opposite end to the cv joint
    Andie0's Avatar
    Aug 2012
    487
    Culd spend silly money fault finding....
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    626
    Quote Originally Posted by paul26982 View Post
    and your still getting the knocking noise?
    Mine makes the noise even driving on a nice flat ground too!
    Mar 2008
    Oldham, Manchester
    1,109
    without stating the obvious but if you've changed everything and it wasn't there before you fitted the coilovers then it sounds like a faulty strut within the coilover setup cv joints inner or outer wont cause a clunk going over bumps... as i said earlier they click when on full lock.... were they a respected brand of coilover ?? could you not refit your old springs and struts and see if goes away ??
    Dec 2006
    barnsley
    1,016
    what coilover set ups are you guys running ???
    im looking around for one myself for my s4
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    626
    There the fk highsport mid priced ones. I read on another audi site,guy having exact same probs as some of us,went back to springs,noise gone to??
    Theres guys and gals with budget coils on with no noises what so ever????
    Ive checked the struts loaded + unloaded. Solid. I will get to the bottom of this....just watch this space
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    626
    [QUOTE=dualmono21;1904001]what coilover set ups are you guys running ???
    DPM - Audi A4 B6 Coilovers
    Andie0's Avatar
    Aug 2012
    487
    I run dgr coilovers, are pretty good for a relatively unknown make! They are pretty much d2 copies... Have been round few different tracks on them and was really happy with their performance... Rebound rates are good and keep all 4 wheels on the floor most of the time! I do get a knock once i fitted them but i have changed a few suspension components amd still get it but it seems to be something to do woth the coilover itself as goes away when i turn them to soft! But then again ive been i. Some well set up track cars that are npisy as hell through the stiffness so i think its down to me stiffening everything up so much
  1. Knocking noise after coilover install
    By eugeneuk in forum A4/S4 forum(B5 Chassis)
    Last Post: 21st January 2014, 13:46
  2. Best Coilovers ?? / knocking noise on rear ??
    By maddrick92 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 9th October 2012, 12:20
  3. HELP! Knocking noise after fitting v maxx coilovers
    By Paul-S3 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th April 2012, 17:55
  4. JOM coilovers fitted, knocking noise at front (pics) help!
    By wez3570 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 5th April 2012, 18:15
  5. Vmaxx coilovers slight knocking noise 2.0T quattro
    By jakeward46 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th November 2011, 15:43
