Results 1 to 7 of 7
    Nov 2012
    Warwick
    39
    Cruise Control fitting question
    Hi all,
    Looking into fitting cruise control to my 1.9tdi quattro B6. Will fitting the hardware without plugging it into VCDS cause a problem?
    The reason I ask is I was thinking of fitting the control module and switch on my drive but then will need to drive to someone who can re-program via VCDS.
    Thanks,
    Tom.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,536
    Should be fine but not work as the ECU will not be looking for it as you would not have programmed it yet.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Nov 2012
    Warwick
    39
    Ok thanks, I understand it wouldn't work, just checking the car would still work until I can get it plugged in.
    Tom.
    Stu-pid's Avatar
    May 2013
    80
    It will all work fine as that is what I did DIS stalk.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,536
    Will be fine
    Mike
    - BUILD THREAD >>
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    You'll no doubt have ABS/ESP and air bag warnings so drive safely!
    A4 Avant 1.9 TDi Sport GmbH
    Oct 2009
    Hull
    1,437
    as above you will have some warnings
    I had a member come to me for coding the cruise after he fitted it and he drove about 100 miles
  1. Parts for cruise control fit?
    By Issac Hunt in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 1st September 2009, 00:07
  2. Retro fitting cruise control part question
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 22nd February 2009, 22:39
  3. A3 Cruise Control Fitting
    By rosscotdi in forum Awesome GTI
    Last Post: 16th May 2007, 10:17
  4. Just had cruise control fitted
    By markpetty in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 22nd June 2005, 12:27
  5. Cruise Control - Fitting
    By Cage in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd June 2005, 21:48
