Volks AutosJMB Retrofits
Results 1 to 11 of 11
    Andie0's Avatar
    Aug 2012
    487
    Secondry air pump
    Hi all, can i delete this and if so what do i take out and is there anything i needto buy in order to do this properly?
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,323
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    Need mapping out once done can pull it out, basically it's just for omissions for the cat
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
    Dec 2006
    barnsley
    1,021
    its used when you first start the car up and the car runs rich extra air is blown through the system to try and dilute the gases
    delete it and remove it by all means but in the long run it will shorten the life of your cat
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Aug 2009
    north east U.K
    1,323
    As above couldn't be bothered to right it all, worth doing if you going decat
    May 2013
    47
    Visit _adam_'s Instagram Channel
    This was something i was looking just to simplify the engine bay more than anything, is there a blanking kit of a guide anyone knows of ?
    Mar 2013
    Near Oxford
    406
    you can fit a resistor to stop the CEL. I did the delete on my old car as the SAI was noisy. All it does is blow warm air onto the cat to try and lower emissions, I cannot see how it can shorten the life of the cat at all, unless by cat you mean the neighbours moggie who is breathing in the emissions, then yes it will shorten the cats life.
    Andie0's Avatar
    Aug 2012
    487
    I have no cat now anyway! I have a revo map will they be able to adjust the ecu to suit if i take it back there
    Aug 2009
    north east U.K
    1,323
    No as there are a generic map you need a custom one
    Dec 2006
    barnsley
    1,021
    if you have no cat now then fine , but in your sig you list a 200 cell race cat ,
    if you did the mod and removed the secondary air pump while still having this installed over time when starting the car
    the cat would become saturated due to the excess emmisions
    kwistof's Avatar
    South East Events Moderator
    Jun 2010
    SE Kent
    2,283
    Follow kwistof On Twitter Visit kwistof's Youtube Channel Visit kwistof's Instagram Channel
    Quote Originally Posted by _adam_ View Post
    Here you go -
    Forge Motorsport FMEGRBP Secondary Air Systems Blanking Plate A4 B6 Avant / Saloon 1.8T FWD, 1.8T Quattro 11/00> - £21.10 : The premier online mail order VAG suspension and performance specialists. We offer a wide range of all the best branded suspe
    From a site sponsor as well...so Win Win
    2000 S3 APY
    18" BBS RSII with Michelin PS3s, 20mm H&R adapters, Relentless 3" DP and Sports cat, B5 V1 induction kit, cone filter+heat shield, Forge 007P, Awesome GTI SMF, AP coilovers, Facelift rear lights, Full Powerflex poly bush kit, R32 Rear ARB, SAI delete, N249 by-pass, Upgraded Engine mounts with Polytek, Stage 1 CC at Badger 5.
    Andie0's Avatar
    Aug 2012
    487
    Havent updated sig soz, i had a 200 cell on there but gutted it and rewelded it back together to work as a decat! I am very happy with my map and didnt realise there would have to be a custom map done after deleting secondry so i think i will just leave it as car is tip top and reliable as it is! Thanks for your advice people
  1. Advice on removing secondary air pump please!
    By mark_sarah in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th February 2011, 17:13
  2. Secondary air pump.
    By JayMc in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th September 2009, 15:42
  3. Secondary air pump
    By Effect in forum A3/S3 Forum (8L Chassis)
    Last Post: 9th September 2009, 19:13
  4. Secondary Air Pump - noise
    By comdw in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th October 2007, 11:38
  5. auxillary air pump (secondary)
    By RichWalk in forum A3/S3 Forum (8L Chassis)
    Last Post: 28th June 2005, 16:39
