Ideally you will need just a fascia IF you have a symphony/double DIN as standard. If you have a single din then you will need the cage and also the climatronic...
As above, if you don't already have a double din unit in place, you will need to fit a double din cage - centre console needs to come out for this. The climate panel can either be replaced, or you can trim the edges of your current one.
DD. cage is about £38 from tps not £100 +, used climate units are easily avalible or an even cheaper route is buy a knackard climate unit and trim the face plate to fit your good one depending what you inten to fit RNSE or aftermarket a facia surround will also be needed.
