AH FabricationsSky Insurance
    munchkincoupe's Avatar
    Aug 2010
    971
    Driver's door lock won't work with key
    I've searched and can't find anyone who has had the same issue. I've just refurbed my non-working key with new pad and battery. I need to sync it but my driver's side door loak won't open or close with the key. It works fine with the remote central locking, will lock/unlock with the interior switch, has never failed to catch and all interior lights come on as normal and it is detected on the dash when it is open. Both of my keys can't open it, both will open the boot lock and both will start and drive the car without issues.
    It wouldn't be a problem but I can't sync the refurbed key using the process in the manual without being able to manually lock/unlock the driver's door lock
    Can anyone help me out please?
    Oct 2009
    Hull
    1,433
    does the barrel turn? if not then sounds seized up a bit of penetrating oil will help
    Aug 2010
    971
    It turns but not far enough. I don't want to force it as the keys start to separate with too much twisting. I've opened the lock aperture and liberally sprayed WD40 in it earlier today but no joy yet
    Aug 2010
    971
    Right the driver's door will now manually unlock only with both keys now but only if the 1 working remote has already been used to unlock it with central locking. The lock will not manually lock with either key. It will lock with the remote or from the internal switch.
    My non-working remote key will start and drive the car.
    Any help much appreciated fellas as I can't really afford to go to the stealers at the moment
  1. Drivers door lock will not unlock with key - HELP
    By graves_x in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th April 2012, 23:39
  2. Audi A3 drivers side door lock not working
    By rick28 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 2nd August 2011, 01:35
  3. Allroad nearside rear door lock won't work using central locking! Help!
    By buftonian in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 15th January 2011, 22:07
  4. Changed battery now remote locking won't work
    By Nickl in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th July 2009, 21:32
