Chris NottAH Fabrications
    Jun 2013
    Audi A4 tdi 2.5 Sport Convertible 2003. Temp guage problem & ESP Light problem
    Hi,
    I have a problem with the temp guage not registering at all. Could it be the thermostat? or worse ? also have a problem with the ESP light that stays on when driving. Keeps going off then comes back on and stays on.
    Would appreciate any advice. Would it be a sensor and any ideas on cost?
    dkarod1
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    Quote Originally Posted by dkarod1 View Post
    Hi,
    You wanna hope it's not the thermostat mate as its situated behind the water pump so it's effectively a cambelt and water pump change! I had the same problem with mine a couple of years ago where it wasn't warming up past 70 degrees, cost me £900 to have the thermostat changed :-/
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
    Jul 2007
    770
    Does the engine warm up quickly? heater good and early ?if so the stats OK and it could be the coolant temp sender which is quick and easy to change.A diagnostic check would cover the TPS but not the stat.The ESP could be a faulty brake light switch but again a check would show
    Jun 2013
    Quote Originally Posted by Mike B View Post
    Many thanks, Yes the heater is good and early and the engine warms up quickly. I am hoping its the temp. sender. Am having the check via a diagnostic and see where it goes.
    The ESP i think is with a sensor on a wheel. Today when driving the light went off but there was a squeeking noise from one of the wheels, the light came on and the squeeking went!
    Jun 2013
    Jun 2013
    [QUOTE=Az;1890935]You wanna hope it's not the thermostat mate as its situated behind the water pump so it's effectively a cambelt and water pump change! I had the same problem with mine a couple of years ago where it wasn't warming up past 70 degrees, cost me £900 to have the thermostat changed :-/[/QUOTE
    Am having a diagnostic check done tomorrow and hope it isn't the stat! Thanks for the info.
  1. audi avant tdi 1.9 sport
    By darcar in forum General Technical / How To
    Last Post: 24th December 2013, 18:48
  2. Audi A3 1.9TDI Quattro Sport (PD130) (2003)
    By Kave in forum For Sale/Wanted - Audi Cars
    Last Post: 14th June 2011, 22:55
