Sky InsuranceVolks Autos
    May 2013
    West Sussex
    9
    Intermittent Traction control and ABS lights
    Hi.... I seem to have an intermittent problem with the Traction control and ABS lights both coming on.
    It seems to be completely random as to when it happens and if i turn the engine off and re start the car the problem doesn't happen for the rest of my journey.
    Is this common?
    Richard.
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    It could be one of several issues, without a VCDS scan you're clutching at straws.
    Next time it does it, see if the brake lights work - a faulty pedal switch can often give the warning light combination you've mentioned.
    Chris-Vspec's Avatar
    Mar 2013
    Verwood, Dorset
    248
    +1 for the above, could also be a steering angle sensor, as James said would benefit a diagnostic check in the first instance.
    Jan 2011
    Scotland
    When I had this problem (on my S8) it turned out to be a faulty ABS sensor, do you feel the ABS kicking when stopping from very low speeds ie in traffic as well? that was another symptom of mine
    Nov 2012
    Mine does the same when I turn my HIDs on!
    Paul @ Unit's Avatar
    Aug 2009
    north east U.K
    1,321
    Add Paul @ Unit on Facebook Visit Paul @ Unit's Instagram Channel
    I get this and speedo goes off too, always get the code for front left wheel speed sensor but replaced about 3 times with new ones and doesn't help I'm in the process off finding the fault checking things
    2003 B6 Audi A4 Avant. 3.0 V6 Quattro Sport
  1. A4 randomly showing traction and ABS lights
    By AudidriverA4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 7th April 2013, 12:53
  2. 8l s3 traction control and engine management lights constantly on
    By rob fulham4eva in forum A3/S3 Forum (8L Chassis)
    Last Post: 11th May 2012, 08:34
  3. Traction and abs light come on after checking fuses
    By johal87 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 15th November 2009, 20:50
  4. ESR and ABS lights on
    By stevedsteve in forum A8/S8 forum
    Last Post: 28th February 2009, 20:36
  5. Tranction control light and ABS light
    By S90GAV in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2008, 21:48
