Chris NottJMB Retrofits
Results 1 to 24 of 24
Like Tree3Likes
  • 1 Post By Audi Doodah
  • 1 Post By boost-addict
  • 1 Post By deano1978
Thread: gear box question
    Audi!
    Apr 2013
    Kent
    56
    gear box question
    Would a gear box oil change stop the gear selection being so 'clicky'? Especially first and second gear, they're not over easy to select, and if your windows are down for example- its quite noisy as you put it in gear.
    Any knowledge appreciated!
    Jul 2007
    770
    Might be the clutch otherwise Molyslip could help or its just wear
    Audi!
    Apr 2013
    Kent
    56
    Molyslip. . . as in do a gearbox oil change to molyslip?
    Jul 2007
    770
    Just add it to the new oil.Helped with my wifes Bora which was notchy in 4th and 5th but if its 1st and 2nd its more likely the synchro is dodgy or the clutch is failing
    Andie0's Avatar
    Aug 2012
    487
    Mine is also clciky is first and second always has been and selects fine with no resistance! Just seems to make that noise, changed the fluid and no change!
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    I did an oil change and it improved the notchiness I had. Had a new clutch fitted not long after and saw furthur improvement. Can still hear my linkage with windows down though...it is mechanical movement, after all.
    A4 Avant 1.9 TDi Sport GmbH
    boost-addict's Avatar
    Aug 2011
    977
    could be gear linkage bushings that have worn. creating a poorly selected gear.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Quote Originally Posted by Audi Doodah View Post
    how did you find out which oil and how much? Mines 04 sport like urs.
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Sep 2012
    Swindon
    371
    75W-90 Fully Synthetic, so says the Audi bible. Give me your gearbox code off your service sticker and I'll check the capacity.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    where is mine? Am i looking for special sticker with info on it?.
    Dont seem to have one! Not in boot,engine bay or door arch??
    May 2013
    redditch b98
    356
    Add bradh on Facebook
    Try under the rear bench seat that's ware I found mine
    Sep 2012
    Swindon
    371
    It is on the first page of the service booklet too but I suppose you can't find that either!?
    All the 6 speed boxes have a 3 litre capacity and I used Castrol in mine (see the link) but the Audi part number is G 052 911 A
    A mini how to in this thread
    deano1978 likes this.
    Aug 2011
    977
    If you pm me your reg ill look it up at work.
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Quote Originally Posted by boost-addict View Post
    appreciated...R15 DDH
    Aug 2011
    977
    lol im not at work any more, let me see if i can access a website we can turn to at work if our system dosnt show any info
    Aug 2011
    977
    need your vechile details, its not telling me decent enough info
    need model, spec, enigne size (more importantly what bhp one if theres variants) and year
    Aug 2011
    977
    dw done it
    Code:
    Engine (DT) EDGE 5W-30 (a) 4.0L
    Manual Transmission Syntrax Long Life 75W-90 2.3L
    Automatic Transmission Refer to main dealer 4.5 - 5.0L
    Differential From Gearbox
    Coolant G13
    Brake Fluid React Performance DOT 4
    Multitronic transmission, differential Refer to main dealer
    Wheel Bearings Multipurpose Grease
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Thanks boost-addict :-)
    boost-addict likes this.
    Aug 2011
    977
    Aug 2011
    977
    Sep 2012
    Swindon
    371
    Exactly what I used and linked to in my mini guide £12.99 a litre or £10 with a trade card.
    Aug 2011
    977
    I missed the link. That or the advanced multigear one. Same stuff, different bottle
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    625
    Thanks very much for your help.
    Newbie
    May 2013
    Isle of Wight
    9
    I got the same thing going on too! 2004 1.8 t 190 , 2nd is a bit of a crunch but when warmed up is fine ,new clutch about 5k ago. Is it a common thing with the a4s ?
  1. Gear box question
    By Niknak in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th September 2008, 18:50
  2. Gear box, Air con console, & aerial questions
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th May 2006, 22:06
  3. Gear box
    By starski4578 in forum A3/S3 Forum (8L Chassis)
    Last Post: 8th September 2005, 11:38
  4. reprogramming a DSG gear box ?
    By spiider in forum A3/S3/Sportback (8P Chassis)
    Last Post: 16th May 2005, 15:30
  5. Gear box oil
    By duane in forum A4/S4 forum(B5 Chassis)
    Last Post: 13th April 2005, 21:07
