Volks AutosEM Tuning
    tbs
    Nov 2012
    44
    oil top of engine 1.9tdi
    1.9 td iIm noticing oil spray at the top of the engine around the silver round thing. ( technical term) Its not horrendous just messy. Ive cleaned up around it but I guess it will happen again gradually. How can i stop this and whats causing it to happen now. Any advice welcome.
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    Leaky egr valve.
    A good clean of egr and manifold will help.
    tbs
    Nov 2012
    44
    Thats a messy job I really don't need. Is the valve leaky because of crud build up or does it need replacing?
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    The oil will most likely be leaking from where the intake pipe joins the egr as it's not the best mating ever designed. The oil comes from the turbo seals and the crankcase breather and is normally burnt off in the engine...white smoke when booting it. It could be that your egr & manifold is clogged, causing the oil to pool and get forced out of the egr/intake pipe union.
    A4 Avant 1.9 TDi Sport GmbH
    Jul 2012
    432
    Take it out and check, guess work is useless.
  1. oil leak from top of engine on the right hand side
    By harvey01 in forum A3/S3 Forum (8L Chassis)
    Last Post: 1st January 2012, 20:45
  2. OIL LEAK 1.8T SPORT CONVERTIBLE - From rear & top of engine?
    By stinkypete in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 1st January 2012, 19:29
  3. Oil feed on top of engine
    By nak in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th August 2009, 20:02
  4. oil top up 2.0 tdi
    By a3guy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2007, 17:05
  5. OIL TOP UPS
    By JohnBoy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 31st December 2004, 20:02
