AH FabricationsJMB Retrofits
Results 1 to 12 of 12
    Nov 2012
    Warwick
    41
    Windows all open mystery
    Hi all,
    Woke up Sunday morning, looked out the window at my A4 to see all 4 windows fully down! (I have 4x elec windows) I had definitely not left it like that. Haven't used the rears for weeks.
    Ran downstairs to check my can and all looked fine, nothing has been taken, lucky it was a dry night.
    Anyone else experienced gremlins in the electric windows?
    I thought after maybe my car has had the auto windows programmed and I had accidentally pressed the key fob in my pocket, but no it doesn't have the auto windows via the key fob.
    Tom.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,571
    Are you sure about the remote. It can also be activated by the door lock by key if someone was tampering with that.
    If you have VCDS you can deactivate the feature so that it cant be done via door lock or remote.
    My wife has done this with her Mk5 Golf and it ended up being the crap in her handbag pressing on the remote LOL
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Dec 2006
    barnsley
    1,016
    if your positive it does not have the auto windows programmed via remote fob
    there is only 2 other logical solutions
    1. malfunction with the electrics
    2. somebody has a key for your car
    personally i would check the car with vcds and disable the feature completly then wait and see if you either have a malfunction or
    someone still able to access your car
    if you do you could have the keys reprogramed to stop the car being thieved , but they would still be able to access the car
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    This has happened to me once, the only logical conclusion I ever reached is that the car was locked, and I pressed and held the unlock button long enough to unlock the car and lower all the windows (in my experience auto lock is enabled by default?) - then as no doors were opened it auto locked itself 30 seconds later. It's a bit odd, and freaked me out at the time but it's only ever done it once!
    Nov 2012
    Warwick
    41
    Ah thanks,
    So to double check my key fob, for the windows to auto open, the car should be locked or unlocked?, then hold unlock on the key fob until the windows open?
    And to close them, should the car be unlocked or locked, and then the lock button held down?
    Tom.
    jb0o's Avatar
    North East Forum Moderator
    Feb 2009
    North East, UK
    2,609
    The car can be locked or un-locked for the Auto open/close to work, the button just needs to be pressed twice in quick succession and the second click held down.
    Do you tend to keep your car keys in your pocket as I'd put my bet on the keys being in the pocket being the problem here.
    Website | Facebook | Audi TT 2.0TDI 170 Quattro
    JasonS's Avatar
    Feb 2012
    North Herts
    90
    I did the same with my Cabriolet.. Except I somehow pressed the unlock button 3 times from my pocket while having breakfast.
    I went out to the car an hour later to find it unlocked, with the top down.
    (I have a remote roof module fitted)
    Fortunately nothing was missing and it hasn't rained.
    I took to leaving it with the hood storage flap in the up position, so I couldn't repeat the episode.
    But since then, I haven't managed to do it again.
    2005 A4 Sport Cabriolet 2.5 TDI
    Previous Audis:
    1997 A6 Avant 2.5 TDI Quattro
    1994 80 Cabriolet 2.0
    1995 S6 2.2t 20v Quattro
    1998 A6 Saloon 1.8t
    1995 A6 Saloon 2.0
    Nov 2012
    Warwick
    41
    So I can confirm my car does have auto windows.
    Must have pushed the key fob button when in my pocket...
    Tom
    Jun 2013
    Kent
    27
    Quote Originally Posted by SuperV8 View Post
    Tom
    Glad it was nothing sinister. I used to sell Skoda's and I made sure one of the things I always showed new customers was that feature and how it could be set off by accident. I also used to show them how easy it was to loock the keys in the boot after using the boot only open button. I only did that after I did it myself!
    May 2012
    64
    My Mrs has a mk6 golf and on a few occasions has left work to find her windows open, vw said its a fault that sometimes happens even though the key fob wasn't touched.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,571
    It can be disabled for peace of mind with VCDS/VagCom
    Mike
    - BUILD THREAD >>
    Nov 2012
    This happened to me but just with the drivers window. I lock the car on the harbour and let to sea (I'm a fishermen) on the second day of the trip I get a call saying my drivers window is down but all 4 doors are locked. There's no way it had any thing to do with my keys as they where 25 miles off shore! Luckly the waterproof key was in the glove box so my friend could close the window and lock it again. I noticed when I got back that my auto down stopped working drivers side but fine the other. But it's fixed it self now and all seems to be fine
  1. Auto window close / open...?
    By burnsy79 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 27th March 2012, 16:22
  2. Windows all open by about 2"'s on my Audi A4 AVant Sline
    By marballs in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 7th June 2011, 12:24
  3. All Windows open/closed
    By pcmanning in forum A3/S3/Sportback (8P Chassis)
    Last Post: 8th October 2009, 10:42
  4. windows found open? very strange!
    By cnpaterson in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 28th November 2005, 15:20
  5. Programming Keyless window closing / opening
    By imported_paranoico in forum General Technical / How To
    Last Post: 20th September 2004, 20:45
