Monster MotorsportVolks Autos
    Andie0's Avatar
    Aug 2012
    487
    008 spring rate change
    Right i was helping a guy on here last night about fitting his diverter valve and remembered that i hadnt changed my spring rate in my 008 after getting the revo map! With the green spring in i was holding 15-16 psi and after changing to the yellow spring i am now holiding 18-19! Took the car out and feels much better, must have been losing boost through the wrong spring setup in valve!
    Just letting no incase you guys havent set up your spring rate correctly that it can gain you good results
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    Oct 2010
    340
    Yeah I ran yellow spring on my golf mk4 an yellow spring on the actuator. Admittedly I was hitting 25 psi with stage 2 on k03s.
    Andie0's Avatar
    Aug 2012
    487
    Well i peak 23 psi on ko3s so not far off...
  1. S3 (8P) OEM spring rates and arb size
    By volkskid in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th March 2013, 13:48
  2. Which Spring Rate would i need
    By pink.teg in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 12th February 2012, 18:35
  3. Spring rates and damper questions
    By iqbad in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th September 2010, 18:45
  4. s4 spring rates
    By 205man in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd July 2010, 11:23
  5. Spring rating colour codes
    By imported_rustys3 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2005, 11:22
