Sky InsuranceChris Nott
Results 1 to 11 of 11
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    442
    Question Oil level waring keeps coming on
    Has anyone experienced this problem?
    2003 S4 103k miles, every now and then the oil level icon pops up on the DIS but I check the oil and it's at an acceptable level. Once checked the icon disappears.
    Has anyone else experienced or have any good ideas? I know these motors use oil so I am always nervous about the oil level and this isn't helping.
    cheers
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    I wouldn't worry too much about it. I had the same problem with mine a few years back, it was intermittent but quite frequent, and like you say I'd check the oil level and it was fine. So had it checked out at a vag specialist and they traced it to some damaged wiring close to the oil level sensor. They stripped back the wiring and replaced it with fresh wires and I've not had the warning come back on since. Either that or it could be a faulty sensor.
    One thing I would say though, is that the red oil can warning on the DIS can also mean oil pressure, so it might be worth having the oil pressure tested, the vag specialists who did mine mentioned this to me and carried out a pressure test which came back fine luckily, but it might be worth having it checked out too.
    B6 A4 2.5 V6 TDi Quattro Sport
    Dolphin Grey I 210 BHP Remap I KW V1 Coilovers I 19"x9.5" all round BBS LM reps I RS4 Anti Roll Bar Kit I S4 Front and Rear Bumpers I Votex side skirts I S4 Aluminium Mirrors I S4 Rear Spoiler I S4 Style Tailpipes I USDM S4 licence plate blank I 6000k HID's I 18 SMD DRL's I Cupra R Splitter I Full RS4 black leather with white stitch optional bucket seat interior I RS4 black headlining I TT S Line FBMFSW I Aluminium Trim I Reverse camera I Full DIS I Cruise Control
    Mar 2013
    Near Oxford
    360
    Is it definitely level and not pressure?
    Az
    Az's Avatar
    Hard slammed!
    Jun 2008
    Hertfordshire
    1,023
    In the owners manual it says to initially check the oil level when the warning displays, then if the level is ok but the warning remains to take it to an Audi dealership. But as said, it also doubles as an oil pressure warning. Low oil level goes hand in hand with low oil pressure anyway hence why the manual says to initially check the oil level.
    Dec 2006
    barnsley
    932
    is it the yellow warning or the red warning ???
    yellow is oil level warning
    red is oil pressure
    if it is red do not drive the car until you have had it checked out
    have a look behind the back of the oil filter on top of the engine about 3 or 4 inches down is the oil pressure switch
    it should have a single wire connection
    you could change the oil pressure switch as it should only be a few quid
    if your still getting the red warning after changing the switch then you need to do a manual check of the oil pressure
    remove the oil pressure switch and insert a manual or digital pressure gauge into the thread for the oil pressure switch and post up what your getting
    if this doesnt cure it then youll need vcds there are a couple of settings which can sometimes default to 0 which can give trouble
    if its yellow and keeps coming back up the sensor could have been damaged by turning the igntition on without any oil in the sump
    the sensor is in the sump of the car
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    BRILLO's Avatar
    Sep 2011
    Juniper Green, Edinburgh, United Kingdom, United Kingdom
    136
    My mate had this problem on his s4. I changed the sensor in the sump and been ok since.
    colinurquhart's Avatar
    Jun 2009
    200
    Was the sensor hard to change and expensive?
    2006 Audi A6 2.7 tdi Quattro S/line
    GONE BUT NEVER FOGOTTEN 2003 Audi S4 B6 Avant, LPG Converted, 19" BBS Speedlines, Stainless Creations Custom Exhaust.
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    442
    Thanks all for you info.
    The warning is the yellow "min level" indicator, never seen the red. I had the sensor changed a few months ago as this has been going on for sometime. I'll get my guy to check it again and check the wiring condition. Also get him to do an oil pressure check at the same time.
    Has anyone had this issue and had it connected to the breather pipe, or does anyone know of any issues with the breather on the v8, i have heard of issues with other breather pipes on other motors?
    chrs
    BRILLO's Avatar
    Sep 2011
    136
    Quote Originally Posted by colinurquhart View Post
    its easy to change once you have the under tray off. Just 2 bolts and a gasket. Think it was £60 or £80 pound from Audi
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    442
    yes, when i had mine replaced it was £74.90, just checked the bill.
    Jun 2009
    200
    Cheers guys
  1. Checking Oil Levels / Consumption
    By mattyboy199 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th February 2006, 00:35
  2. Replies: 8
    Last Post: 19th January 2006, 23:06
  3. A4 B7 2.0TDi Low Oil Level Warning Light
    By stedes in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 3rd November 2005, 18:31
  4. Carriage FREE oil offer (limited period) coming soon!
    By imported_oilman in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th September 2005, 13:19
  5. Minimum oil level - DIS
    By dik in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th July 2005, 01:06
