JMB RetrofitsEM Tuning
Results 1 to 21 of 21
    s-line style's Avatar
    May 2013
    co durham
    53
    dump valve location please?
    just bought me first audi about 5 weeks ago really happy (except spending a fortune on petrol) its a 54 plate s-line the 190bhp engine anyway just bought a dump valve for it and because am new to audis am not sure about locating this fitting ect but I have a feeling theres some clever people on here who can help (: pictures of where standard one is would be highly appreciated as my aftermarket one is sat in me glovebox longing to dump
    Andie0's Avatar
    Aug 2012
    487
    image hosting 15mb
    driver side under car near front bumper, easy job!
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    Andie0's Avatar
    Aug 2012
    487
    Mke sure it is a recirculating valve or your car wont run properly! Even the split r ones are not good... That one there is the 008 from forge and is really good with adjustable internals to suit different boost pressures
    May 2013
    co durham
    53
    cheers mate now a know where a wanna put it on now ha shame its dark and yeah its an atmospheric recirculating one is yours the 190 aswell? coz a lot of ppl reckon all the 1.8t engines are the same which I disagree as ive seen this dump valve on top or near top of engine on other ones
    Andie0's Avatar
    Aug 2012
    487
    Yer 190 differ in many ways from other 1.8t! I have 190 too great car mines moddwd though wna go further with it now though big big turbo
    May 2013
    co durham
    53
    Quote Originally Posted by Andie0 View Post
    Me n me mate just tried fitting the split r dump valve it's dumping but as soon as we let off the revs it's cutting out and when we start it up its running lumpy
    Stu-pid's Avatar
    May 2013
    80
    The split r is a pita to set up I've been there with my old Leon Cupra r. Try it on full recirculating. Have you got a boost gauge so you can see if its set up right ?
    May 2013
    co durham
    53
    Some info would be nice as we are on trying to sort this out now and a don't really wanna knack me car if we keep tweaking this dump valve to try and make it work it comes with 2 adapter type things that are different sizes is the right one important and enough to be making it run lumpy if we have wrong one on???
    Andie0's Avatar
    Aug 2012
    487
    Put it on full recirculating there ap pain them split r's better off with 007p or 008! Our cars just dont seem to like them... If you want the whooopp doooshnh sound fit an open cone filter with heat sheild
    Andie0's Avatar
    Aug 2012
    487
    Dont let it dump to atmosphere at all
    May 2013
    co durham
    53
    weve tried going to the limits on Turing both ways still cutting out and running lumpy do you think them 2 adapter /valve thingys it came with are important?? Coz the one on my original DV is a different size connector to the type we are trying
    May 2013
    co durham
    53
    Quote Originally Posted by Stu-pid View Post
    a haven't mate surely there must be a way for it to work :s
    Andie0's Avatar
    Aug 2012
    487
    Yer have you tryed fitting other way, you need to fit the blank to the valve so no air dumps
    Andie0's Avatar
    Aug 2012
    487
    Take cone off and fit blank
    May 2013
    co durham
    53
    then a might as well put the factory one back on lol I want the dump which it has been doing just its cutting out and not running properly so do you think this split r DV is no good
    Andie0's Avatar
    Aug 2012
    487
    It will never run properly with a split r
    May 2013
    co durham
    53
    Cheers guess al put the placker scrapper one back on the split r one is being a right hassle and waste of money so do the forge 008s make the tsssh noise
    Andie0's Avatar
    Aug 2012
    487
    Therw should be three ports on the valve two which need to be connectd up to original and then one which is used as the dump! This one meeds to be covered witht the blanking plate because these engines are not made to dump the air out, they work best with the air rcirculating bk around system! The purpose of a uprated dv is not to get a dump sound but to hold higher levels of boost pressure. Like i said if you wont the dump you need to install and open cone filter and it ill give you the noise you are after like mine
    Andie0's Avatar
    Aug 2012
    487
    Veiw my buildthread and watch the video i posts of dv noise see f you like
    Starting my build
    May 2013
    co durham
    53
    and you have the forge diverter valve I see what you mean about all that coz it is the noise I'm after and now av gathered this stupid split r one is no good even though I was told it was by the shop selling it on eBay
    Andie0's Avatar
    Aug 2012
    487
    Shops talk **** just to sell you product... You need an open cone air filter if you want whooopp doooshhh not a dump valve these cars are different
  1. Best Diverter Valve/Dump Valve
    By ScottyKemp in forum A3/S3 Forum (8L Chassis)
    Last Post: 23rd September 2003, 13:11
  2. Dump Valve/recirc valve?
    By Jinx in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th August 2003, 23:53
  3. Blow off valve or Dump valve ?
    By K212 in forum A4/S4 forum(B5 Chassis)
    Last Post: 17th July 2003, 19:18
  4. Dump valves
    By waynehiscock in forum General Technical / How To
    Last Post: 28th March 2003, 18:15
  5. Diverter Values/ Dump Valves
    By Banwell in forum A3/S3 Forum (8L Chassis)
    Last Post: 13th January 2003, 23:50
