Monster MotorsportVolks Autos
Like Tree1Likes
  • 1 Post By abyrne153
Thread: Need a new turbo for 2.5tdi
    BRILLO's Avatar
    Sep 2011
    Juniper Green, Edinburgh, United Kingdom, United Kingdom
    137
    As above. Been having probs of over boosting for a while now ( code 00575 ) changed map sensor and now being told probably the turbo. It's 100,000 miles now and wondered if its worth cleaning with mr muscle or is it due to go anyway. It's just that I have the money just now for a turbo which isn't always the case. Where's good place to get them from and has a hybrid turbo got any benefit on a standard 180 q. Fancy remapping though.
    beachbuggy's Avatar
    Surrey
    1,745
    Quote Originally Posted by BRILLO View Post
    Drop Adam an email..
    tditurbos@gmail.com
    He will rebuild or upgrade/hybrid your tdi... I person I recommend
    Dec 2006
    barnsley
    1,016
    a friend of mine has the exact same issue with exact same code
    id advise you take it for a spin and log the car whilst connected to vcds then post up the results
    i am going to put mr muscle into his turbo to see if if makes things better
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Mr muscle is defo worth a go. Much cheaper than going for a new turbo! If you have access to VCDS, perform output tests in Engine and one of the tests moves the actuator arm so you can observe it moving freely or not.
    A4 Avant 1.9 TDi Sport GmbH
    Feb 2011
    Ireland
    41
    You can test the actuator arm by removing the 2 10mm bolts that attach the actuator to the body of the turbo. Be careful not to drop them into the V of the engine as they can be tricky to get at. Once removed you can move the arm which should move freely. Any stickiness indicates the vanes are gummed up. Mr Muscle is worth a go. Remove the 3 exhaust flange bolts and pull the exhaust aside. Pump Mr Muscle into the exhaust side using a flexi tube. Put plenty in and work the actuator arm occasionally. You should find it beginning to free up within minutes. Leave for about half an hour and take for a good drive. Make sure and use gloves when handling Mr Muscle as it is very corrosive stuff.
    BRILLO likes this.
    BRILLO's Avatar
    Sep 2011
    137
    Ok guys. Cheers for the replies. Will be trying the mr muscle over the next few days.
  1. Anyone know of a good turbo supplier? Need a new one for my amk
    By philreed52 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2012, 19:46
  2. Need 2 new tyres for front - recommendations and speed rating?
    By Agent_Trig in forum A3/S3/Sportback (8P Chassis)
    Last Post: 12th April 2011, 21:34
  3. Going to need some new tyres for my S3 what to get?
    By paneristi232 in forum A3/S3 Forum (8L Chassis)
    Last Post: 7th June 2010, 11:34
  4. Please help me i need a new turbo :(
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st May 2010, 11:47
  5. what are the signs that you need a new turbo?
    By Jonesy in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th October 2006, 20:34
