Badger5EM Tuning
    May 2013
    21
    rear brakes lights always on but only when lights are on. please help
    Right so normal day driving rear brake lights work fine.
    When driving and turning on side lights I loose power, even if I put my foot flat to floor. Quick lift if the pedal and back on and its fine.
    But with the lights on the rear brake lights are constantly on, all three. Its as if power is sent to brake lights instead of night lights. Makes no difference if I push brake pedal or not.
    I did discount both rear lights and the centre boot brake light then started to work as normal (lights still turned on)
    It does have something wired in, its got light bulb bypass wrote on the box and has a fuse. I pulled out the fuse but still no change.
    Any ideas?
    May 2013
    21
    It has a towbar so the bulb failure bypass could be for that?
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Dodgy headlight switch or brake light switch
    A4 Avant 1.9 TDi Sport GmbH
    May 2013
    21
    Brake lights work fine with lights of so wont be that.
    And I cant see how a faulty headlight switch would make the rears brake lights stay constantly on but the headlights work perfectly fine.
    Is there fuses or relays I can check? Earth for lights?
    Sep 2012
    Swindon
    371
    Trust me, I know it sounds daft but I've read about them causing all kinds of problems. A faulty one can even prevent the car from starting. Links to your loss of power when you switch the lights on.
    Brake light switches can cause problems with false bulb out indications and brake lights always on
    May 2013
    21
    Ok bud ill try that. Cheers
  1. Red brake warning light but only when warm
    By Thacker in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 9th May 2013, 19:35
  2. Main beam lights not working, but work when "flashing the lights"
    By s3mad_dude in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2012, 19:52
  3. Replies: 4
    Last Post: 24th July 2011, 16:12
  4. Replies: 0
    Last Post: 9th September 2010, 12:34
  5. Rear Brake Light DIS warning
    By Add7 in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th October 2004, 17:19
