Monster MotorsportChris Nott
Results 1 to 23 of 23
Like Tree1Likes
  • 1 Post By Stu-pid
Thread: Fitting trip wiper stalk question
    Stu-pid's Avatar
    May 2013
    80
    Just a quick question I have just got the a4 with cruise already fitted but no trip on the wiper stalk can I just buy a new stalk and plug and play or do I need to change a module ?
    Oct 2009
    Hull
    1,442
    No need to change module but it will need coding
    Stu-pid's Avatar
    May 2013
    80
    With vcds? Can you get it for windows 8
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    A4 Avant 1.9 TDi Sport GmbH
    Stu-pid's Avatar
    May 2013
    80
    Which kit do I want vcds lite?
    Stu-pid's Avatar
    May 2013
    80
    Stu-pid's Avatar
    May 2013
    80
    Is there a specific part number I should be looking for ?
    Apr 2012
    lincs
    210
    If you mean for VCDS try Nigel - NHN on here as he is a registered supplier for the genuine kit. Or check the map to see if a user is local to you.
    The coding involves setting the DIS options and needs VCDS or dealer input but as above if your cruise works then the SCCM should be already mid or highline (Cruise Control Retrofitting (8E) - Ross-Tech Wiki)
    part numbers for DIS stalk for a saloon are (you need one of these!!!):
    (1) 8E0953503B
    switch for wipers/wash-wipe operation / for models with onboard computer
    / sedan
    8E0953503B 4PK
    soul (black)
    (1) 4E0953503B
    switch for wipers wash/wipe operation and on-board computer
    / sedan
    4E0953503B 4PK
    soul (black)
    there may be others but 4e or 8e 503b in black should be ok.
    I did a small write up for dis / cruise which links to others:
    DIS and Cruise - Done
    and there's some stuff in the sticky's
    cheers
    And
    A4 2.5 tdi Q sport '02 AKE, "minor modder", 18x8's S4 Avus , Zender Monza's 18x8.5's, aero wipes, interior trim, dis and cruise, real s4 mirror caps, rns-e led, dble din, VCDS owner-learner - GMBH next
    Stu-pid's Avatar
    May 2013
    80
    Thanks for the info most appreciated
    Stu-pid's Avatar
    May 2013
    80
    Got one ordered
    Stu-pid's Avatar
    May 2013
    80
    So I've fitted my stalk but need to get it coded on vag com. Anybody local to Doncaster fancy helping me out
    Oct 2009
    Hull
    1,442
    I'm in hull if you want to take a drive?
    Stu-pid's Avatar
    May 2013
    80
    Yeah don't mind that only a trip down the m62
    Dec 2006
    barnsley
    1,020
    im junction 36 m1 at birdwell barnsley if it helps
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Apr 2012
    lincs
    210
    i'm near gainsborough
    Stu-pid's Avatar
    May 2013
    80
    Cheers guys when is good for you?
    Oct 2009
    Hull
    1,442
    stu-pid I know we have already started to sort something out but if any of these guys are closer for you don't feel obliged to come to me
    go with whoever is best for you I don't mind as long as you let me know :D
    No point traveling further then you need to
    Stu-pid's Avatar
    May 2013
    80
    Cheers mate your all about the same away. It's just whoever is available soon as. Cos it's stopped my key fob working to unlock the car.
    Oct 2009
    Hull
    1,442
    as I say I can do whatever is best for you but it shouldn't have stopped the keyfob working!! have you done the old key in the ignition turn it on and press the buttons this usually syncs it back up
    Stu-pid's Avatar
    May 2013
    80
    I will try that. Is there a certain process.
    Oct 2009
    Hull
    1,442
    Not really just stick the key in turn ignition on and press lock and unlock a few times then remove and try it
    Stu-pid's Avatar
    May 2013
    80
    That's the locking sorted. Cheers bud
    stu_m likes this.
    Oct 2009
    Hull
    1,442
    No worries
  1. Fitting wiper stalk with DIS
    By Newbos in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 15th February 2014, 14:00
  2. Wiper Stalk Question
    By amicallef1991 in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st March 2013, 20:25
  3. Reteo fit aero wipers
    By sprout99 in forum A3/S3 Forum (8L Chassis)
    Last Post: 24th November 2006, 14:59
  4. Anyone fitted aero wipers.
    By JayB5UK in forum A4/S4 forum(B5 Chassis)
    Last Post: 15th May 2006, 20:27
  5. Areo wiper quick question
    By Soupie69uk in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th March 2006, 17:43
