Monster MotorsportVolks Autos
Results 1 to 9 of 9
    71
    tt/s3 225bhp 380cc injectors
    I've currently got these injectors fitted and am getting rich code. Could this be because the s3/tt 225bhp run 2.5bar in the rail regulated and the a4 1.8t runs 4bar with an un-regulated fuel rail. When I got the car remapped would they have taken this into account?
    Anyone ever done this mod successfully before?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    If you did not tell them you was running TT injectors they would have installed a generic map for stock components so take them out and put stock back in.
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,160
    As above, injectors need to be taken into account when mapping.
    If you aren't planning on having a custom map done soon then remove them, as it will lead to other issues (i.e-borewash)
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Andie0's Avatar
    Aug 2012
    487
    I run these injectors in my stage 2 bex and run really well!
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    beachbuggy's Avatar
    Surrey
    1,746
    Quote Originally Posted by seany26 View Post
    If the Ecu pulls more than 23%ish trim it will throw the code and give the eml.
    380cc injectors need to have the fuel map changed over plus you need to ideally run the same for they came from, it's a simple task of fitting a 3bar s3 or TT fpr and copying over the fuelling maps from the s3 225bhp maps. You should have told the guy mapping it fitted the larger injectors.
    Mar 2013
    Near Oxford
    406
    Quote from R-tech facebook page "Yet another 1.8t been running a 4 bar fuel reg and now has a fooked fuel pump.... Stop it!!!!!" aparently it's been covered a lot
    71
    Thanks lads, this helps. Going to have to look into fitting a 3bar fpr to my car if the 386's can't run on the standard 4bar that the built in fpr on fuel filter regulates to.
    Anyone done this, as there is no return to the tank from my fuel rail?
    Jun 2013
    Southampton
    100
    A little off topic here. I plan to have a remap later this year and was going to invest in new injectors too so I can achieve 230hp-235hp. Am I right in thinking that I couldn't use S3/TT injectors on my A4 B6 (190) BEX without changing the FPR? I am going to take a guess at this being a fuel pressure regulator?
    If that is the case can you simply not just get injectors that will work with the existing FPR on my car? or is it just a case of a live map is required instead of a generic one?
    71
    Yes fuel pressure regulator. Our a4's don't have a regulator at the fuel rail, it's built into the fuel filter at the tank because they are returnless system. so it's not a straight swap, for the s3/tt 386cc injectors from what beachbuggy is saying but I'm still trying to find out for sure.should have the info by the end of the day as to what I'm going to do.
    I do believe the 380cc injectors are a straight swap, so prob safer going with them. I did tell my mapping guy that I had the s3 injectors installed and he must not of seen a problem with that. So I'm looking into it now for sure.
  1. S3 225bhp Review - EVO - May 2002
    By amoffat in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th April 2009, 10:53
  2. Injectors
    By Ryanc in forum A3/S3 Forum (8L Chassis)
    Last Post: 27th March 2004, 18:38
  3. S3 injector flow rate/max HP
    By excursion in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th November 2003, 11:43
  4. Injectors
    By AL_B in forum Diesel forum
    Last Post: 27th August 2003, 16:26
  5. I need the part # for 310cc injector..please
    By austurbo in forum Tuning
    Last Post: 1st August 2003, 11:04
