Chris NottVolks Autos
Results 1 to 8 of 8
Like Tree1Likes
  • 1 Post By archemist
Thread: Which stereo?
    Oct 2010
    341
    Which stereo?
    I have an Audi a4 1.8t with a 6cd changer. Thinks its symphony. The previous owner installed gps but not got round to installing a new head unit. What oem unit do I need for sat nav? Does it work ok with iPod or is it aux only and song selection is via the iPod itself?
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,100
    in terms of OEM there's RNS-E but if your headunit's single din then there's lots of work and cash involved to modify your dash and get it in. Not quite sure what you meat by "installed gps but not got round to installing a new head unit", can't have sat nav on a symphony unit unless it's hooked with parrot or something.
    GeoffDunk's Avatar
    Jul 2012
    Norwich
    439
    Symphony to RNS-E is a doddle, really easy to do but does cost a few quid. I swapped mine out and had the RNS-E up and running in under 30 mins and the only tools used where the stereo removal tools.
    Because its OEM it integrates into the vehicle perfectly including the DIS.
    Audi S4 quattro in Dolphin Grey Metallic, Silver leather, carbon inlays, RNS-E, 6 speed manual, electrically adjustable & heated seats, xenon headlights with power wash, cruise control, storage pack, 18" OEM RS4 wheels, RS4 ARB, LED lighting upgrade, FASH plus every bill since new.
    Apr 2012
    lincs
    202
    There's low line and high line sat nav rns-d and rns-e (the d has a 5" screen in the middle)
    RNS-E was designed for the later B7 model and can be retrofitted to a b6 (I've done a single to double and RNS-E from a seat exeo - the latest RNS-e incarnation)
    I wouldn't bother with anything lower than an 'E' and they come in two version mark 1 and 2.
    Mk1 have an lcd screen and can take 2 4gb (Non SH) SD Cards. Mk2's have an LED screen and can take 32gb cards.
    Mk1 ones are easier to mod (VIM) Mk2's can have full(-ish) ipod integration and AMI.
    Neither RNS E will fully integrate with the car - the B6 CCU, etc predates the RNS 'E' so the 'sat nav' element (not the radio or media) won't appear on the DIS until you power down /up or switch from radio / media to NAV on the unit. Simpy the B6 doesn't look for sat nav when it cycles thru the ignition sequence so it doesn't find it. It's a minor issue.
    If you have DIS buttons then once the 'sat nav' is recognised you can cycle thru it and the DIS (fuel etc) displays. The radio / track section will appear on the DIS as it does now.
    Mark 2 with AMI (the A3 8P type not the A4 B8 integrated, etc) will work / link with mp3 / ipod's and there's a number of threads of people who've done it - it's expensive (c £300 for the parts alone)
    RNS 'e' isn't touchscreen and only takes the 1st 5 digits of a uk postcode (you then have to know the street name / number).
    Both can have bluetooth and some models SDS - search on here - multi-function steering wheels are also fun / an issue!
    I like it lots mind and the look is naturally OEM quality.
    link added:
    RNS-E 2011 Mk2 LED in my 2.5tdi QS
    AllyMc likes this.
    A4 2.5 tdi Q sport '02 AKE, "minor modder", 18x8's S4 Avus , Zender Monza's 18x8.5's, aero wipes, interior trim, dis and cruise, real s4 mirror caps, rns-e led, dble din, VCDS owner-learner - GMBH next
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,472
    Quote Originally Posted by archemist View Post
    That's not a B6 issue, it also happens on the B7 when the red DIS is fitted.
    Audi never factory fitted the RNS-E with the red DIS, so they didn't fix the bug in the CCU firmware.
    As said, it's a minor issue - set route guidance active, turn the RNS-E off and back on, and the instructions appear in the DIS.
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    7,947
    as above on the RNS-E
    but what did the last owner fit ?
    Oct 2010
    341
    I will have the car in the next hour
    Oct 2010
    341
    So will check the stereo spec. Anyone got pics? The owner said the gps is already rigged up in the boot?
  1. which stereo loom and fascia for w reg A4?
    By sionic in forum A4/S4 forum(B5 Chassis)
    Last Post: 23rd October 2011, 21:38
  2. Which Stereo Harness
    By Ryanmt in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 9th June 2010, 09:33
  3. Retro-fit sat Nav - which Stereo to Order
    By Spin140 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th March 2009, 05:24
  4. Which stereo do I have?
    By jb0o in forum In-Car Entertainment
    Last Post: 5th February 2009, 18:03
  5. Which Stereo system do I have?
    By Floob in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st September 2007, 10:38
