JMB RetrofitsSky Insurance
Thread: 18057 fault
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    631
    18057 fault
    On checking for codes nothing shows.
    Alls good with motor,no issues at all.
    But when ever i switch main lights on it goes beserk on the dash.
    Abs flashing,speedo stops working brake light flashes.
    With my little fault reader it finds code 18057 which is...missing drive train or somthing to the abs.
    To clear this fault i just turn off and back on. Then its fine?
    Only happens with main beam,not side lights,are switched on?
    Nothing been done to motor that i can think of.
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Faulty headlight switches seem to cause all kinds of problems. One particular fault with them even stops the car form starting unless the lights are switched on!
    A4 Avant 1.9 TDi Sport GmbH
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,576
    As mentioned change the the light switch unit.
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    631
    Will do. Cheers fellas.
  1. I got a fault code - help please. Code 18057.
    By DJ_Troopa in forum A3/S3 Forum (8L Chassis)
    Last Post: 30th July 2011, 10:29
  2. J(92) Audi 80 Sport Intermittent fault
    By clarkee123 in forum Classic Audi Forum
    Last Post: 17th November 2003, 21:44
  3. DIS Fault
    By garethj in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th November 2003, 21:30
  4. Intermittent Fault Warnings
    By A4Owner in forum A4/S4 forum(B5 Chassis)
    Last Post: 18th June 2003, 11:23
  5. Internet fault
    By Wolfsburger in forum Home Cinema, Hi-Fi and Gadgets
    Last Post: 2nd June 2003, 01:32
