AH FabricationsVolks Autos
    Sep 2011
    Cruise control ???? Help please
    Hi there
    i bought a steering wheel control, cruise switch and all cowlings from a breakers
    i fitted dis a while ago with no probs
    but now I have all the parts fitted the dash is lit up with warnings such as ESP abs and brake light flashing
    ive tried guides on coding with no luck
    any help would be greatly appreciated
    cheers
    PetrolDave's Avatar
    Nov 2003
    U.K.
    1,538
    You need to recalibrate the G85 sensor, see the Ross-Tech wiki (it's easier than you think!).
    2006 RS4 Avant (Phantom Black), RNS-E (2010 version inc SDS, HW 070, SW 0220) with AMI (250GB hard disk), Bluetooth + iPhone 5
    Sep 2011
    Hi I've just reset the steering angle sensor the only fault codes I'm getting now are in abs..01486 system functionality test activated
    and in engine I'm getting message missing to something ????
    im half way there tho
    Oct 2009
    Hull
    1,442
    follow this from start to finish and it should all work http://dl.dropboxusercontent.com/u/8...ctivation.html
    if you miss one step thinking that you have already done it then it wont have any of it you must do it all
    Sep 2011
    Cheers for all the help I think I might of cracked it
    going to try it in the way to work tomorrow
  1. A6 cruise control help
    By Ianb4310 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 13th April 2012, 20:43
  2. Replies: 7
    Last Post: 27th March 2011, 07:40
  3. Cruise control help needed in manchester/oldham
    By RyanJonS4 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 15th June 2009, 21:21
  4. Cruise control help needed in manchester/oldham
    By RyanJonS4 in forum VCDS (formerly VAG-COM) forum
    Last Post: 29th May 2009, 16:30
  5. Retro fit Lights and cruise control HELP PLEASE
    By fin in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th October 2007, 13:22
