Chris NottMonster Motorsport
Results 1 to 10 of 10
    czm
    Feb 2013
    217
    B6 Speaker Upgrade
    Hey guys
    I am looking at upgrading the speakers in my wifes 1.8T Avant 2004. Currently they are standard non Bose and have developed a horrid crackling.
    I am not looking at major modding/alterations just plug and play if possible with some extra ommmpphhh would be a bonus.
    What would be my best option?
    2004 BEX 1.8T Silver Avant - RTECH Stage 1 Remap - 211Bhp/236ft Torque
    TEIN Super Street Coilovers - BlueFlame Catback with 4'' Slashed/Rolled Tips
    Pipercross AirFilter- RS6 18'' OEM's - 225.35.15 Falken 452
    Dec 2006
    barnsley
    1,020
    as regards maker wise i would reccomend
    focal, rainbow , audison or hertz in that order
    cost will be as much as your prepared to spend , however good sound does not come from quality speakers alone
    good sound comes from quality installation , anything you cut corners on now will manifest itself when listening to the speakers
    at a minimum i would advise some nice new baffles for the speakers to fit into and
    a couple of sheets of sound deadening behind and around the installation
    2003 pearlescent black s4 avant tiptronic - milltek exhaust - pre cats removed - remapped ...
    koni adjustable suspension front and rear
    alpine f1 dvi9990 -pxah990 headunit and processor - alpine d511r
    4 x focal 5ws midbass drivers - focal audiom 6w midrange - focal tce tweeters - velodyne df 12 sc servo controlled subwoofer
    3 x phoenix gold zpa 0.5 amplifiers
    Jun 2003
    World of my own
    9,813
    You need decent MDF adapters (see ebay) and the JL Audio TR650csi's are really decent for sensible money - easy to fit as well as they don't have a bulky crossover.
    Alex Turner
    Dec 2006
    barnsley
    1,020
    if you buy the mdf adaptors or baffles from ebay id advise you paint them or varnish before installing them
    or they wont last 2 minutes ... mdf is porous so will soak up and hold water
    Jun 2003
    World of my own
    9,813
    Lacquer the speakers as well just to be on the safe side!
    The MDF adapters are mounted to the inner skin of the door so really aren't exposed to the elements, certainly no more than the speaker itself. I must admit I did lacquer mine so it can't hurt.
    Alex Turner
    czm
    Feb 2013
    217
    Quote Originally Posted by AndyMac View Post
    Thanks for the help, so with these I just need the MDF adapters for the fronts and that all?
    Do I need cross overs? Could I update the sub to a Bose one?
    Jun 2003
    World of my own
    9,813
    Yes that's right, the JL's have an inline filter on the tweeter cable instead of a crossover, just like the stock tweeters.
    You can upgrade the sub to Bose, but it's not that simple, you'll need to install the Bose amp, full front to back wiring loom and change the sub itself, definately not worth it for a small improvement. If you are going to those lengths then far better to install a proper sub, similar amount of work for a far greater improvement
    A4 Avant (B6) Stealth sub install
    Alex Turner
    DieselJake's Avatar
    God Mode
    Jun 2012
    Birmingham
    1,348
    Love that guide, really made a good job never would've thought to mount it there, can you use the original sub wiring or do you need fresh wires front to back.
    Jun 2003
    World of my own
    9,813
    You can use the original feeds for left and right pre-outs and remote but you obviously need to run a new power cable. Bear in mind on non Bose you will need a 4ch amp as the stock amp drives the rears as well, or you need to leave the stock amp connected for the rears. If you have an aftermarket HU then you can rewire the rears directly to the HU and run a proper RCA from the sub pre-out.
    Alex Turner
    Dec 2006
    barnsley
    1,020
    most speaker manufacturers protect there speakers from new anyhows with a waterproof coating at the back of the speaker but
    laquering the back of the speakers isnt a bad idea but be carefull and make sure the voice coils are sealed or youll risk
    laquer building up on the coil and grating up and down in the magnetic gap essentially knackering the speaker
  1. Speaker upgrade
    By Defratos in forum In-Car Entertainment
    Last Post: 4th March 2005, 20:00
  2. advice on speaker upgrade please
    By rasA4 in forum In-Car Entertainment
    Last Post: 1st February 2005, 22:53
  3. A3/S3 Speaker Upgrade - Story so far
    By imported_maviceuk in forum A3/S3 Forum (8L Chassis)
    Last Post: 17th November 2004, 19:32
  4. Clarification on Speaker Upgrade
    By Anito in forum In-Car Entertainment
    Last Post: 8th November 2004, 21:43
  5. Bose Speaker Upgrade
    By imported_S3_gm in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th July 2004, 18:12
