****** wiper blades!! help
tweed
NULL
Needed new blades so bought some and gave them the reg so got to be right.
When I went to remove the old ones, I pulled the arm up and the blade dropped out, both sides. Then trying to install the new ones I have the same problem. The little plastic clip on the arm doesn't fit the blade. So I go back and make sure I've got the right ones and apparently they are.
so am I missing a small part?
Where do you lot get your blades from? Part number?
It's possible a previous owner has done the aero wiper arm retro fit hence why the blades identified from your reg don't fit. Loads of wiper related threads in here if you try a search.
Cheers people saying bosch 909 blades so will go back and try them in the morning.
defo not the aero arms.
11
736
39
4K
12
2K
