Sky InsuranceAH Fabrications
Results 1 to 8 of 8
Thread: New Key
    arthurfuxake's Avatar
    Controversial & Contradictive
    Mar 2004
    Manchester
    1,306
    New Key
    I've only got one key for my B6 A4, is it possible to re-code one of the keys available on ebay, or is the key a dealer only thing? I've heard of someone who got a key off ebay and it would open the car, but not start the engine.
    May 2004
    Kent
    179
    Re: New Key
    Hi Lon,
    I don't know about the compatibility of the keys on ebay, but I did have to get one of my keys re-coded by a dealer, and it cost 50+.
    I would assume if it's a genuine audi key you're buying, then you could get it re-coded by the dealer as above.
    Mike
    Mar 2004
    Manchester
    1,306
    Re: New Key
    I also thought so, but the guy says that he bought the key off ebay(genuine audi part) and took it into the dealer to be re-coded and the dealer got it working partially. It opens the doors but does not disarm the immobiliser. The dealer says that a new transponder chip needs to be put into the key-fob to recode it to the immobiliser. Something about the transponder being serialised to the vehicle(or similar gobbledegook). I'm wondering whether he got a pre2001(pre 8E) key fob and there is a compatibility issue?
    gizze's Avatar
    Dec 2003
    Norfolk
    615
    Re: New Key
    I bought a new key direct from the dealer, it cost just under 80 and obviously they code it for you when you collect it.
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: New Key
    the immobiliser part of the key can only be coded once making ebay keys a waste of money unless they are new and have never been coded
    Mar 2004
    Manchester
    1,306
    Re: New Key
    Thanks Pete, looks like I'll have to get a price from the dealer then. I feintly recall a price more in the region of 180, I hope it's closer to your price Gizze.
    Jul 2005
    2,488
    Re: New Key
    i thought it was the other way around.. the car (ecu and speedo clocks) were programmed to accept the immobiliser code in the key? Each key is unique, hence why it remembers your aircon settings.
    If you ever buy a cloned key from a high-street key-cutter, they just copy your existing imobiliser code, so the car thinks its the same key, and you lose the functionality of personalised aircon settings.
    as for ebay keys, be careful, make sure the part numbers are the same, as the remote un/locking transmitters in them all work on different frequencies. Other than that, all you need is to take it into a dealer to get them to tell your ECU to accept the immobiliser code, and cut you a new blade, preferably from your key number.
    Numptie of the highest order
    Jun 2004
    Crowthorne, England
    2,512
    Re: New Key
    This thread might be worth a look, it's for A3s but I'm guessing it's the same for same age cars etc.
    http://www.audi-sport.net/ubbthreads...&page=1#347597
