JMB RetrofitsChris Nott
    glenandem's Avatar
    Sep 2012
    manchester
    528
    rubbery gooey coolant pipe at back of cylinder head!
    hi guys when i was replacing clutch yesterday i had a look up the back of the engine and saw that what looked like a coolant pipe on the turbo side of my 1.9 tdi had gone soft and gooey and looks like it needs replacing sharpish, looks like a pain to get to too!
    has anyone ever replaced this pipe and are they easy to get from above with removing turbo pipe etc?
    also i found an oil leak from around the butterfly,throttle assembley, ive already blocked egr valve off but is there anything else i can do to stop all this dirty oil coming out somewhere?
    Aug 2011
    196
    Can't answer your question about the specific pipe, but this may be of general help regarding oil leaks - Audi A4 Oil Leak - Audi A4 Oil Leaks - Audi A4 Oil Burning Smell - accepting it specifically references the V6, I guess the principles it outlines will be the same? Mike.
    benjie's Avatar
    Oct 2009
    Swindon - home of the 'Magic' Roundabout.
    645
    Is it quite a small rubber hose the comes out of a larger coolant pipe in the middle of the engine bay and runs to the back? If so, I had that changed 8 months ago - tandem pump was leaking & the diesel had perished the pipe. Was losing coolant (enough to trigger a warning) in 20min of 'fast' driving.
    B8 S4 Avant in Misano Red with some lovely toys!
    Prev: B6 A4 Saloon 1.9 TDI quattro Sport - great car.
    glenandem's Avatar
    Sep 2012
    manchester
    528
    yeah thats the one, is it easy to get to?
    benjie's Avatar
    Oct 2009
    645
    I didn't change it, garage did. For what it's worth, they didn't say it was difficult... apparently access to the tandem pump to change the seal was very tricky.
    glenandem's Avatar
    Sep 2012
    manchester
    528
    cheers pal, ive only seen it from underneath when i did the clutch and dmf but im gonna take engine cover off today and see what needs moving, hopefully wont be too bad!
  1. 54 a3 tdi 140 coolant lose/cracked cylinder head check?
    By aterro in forum A3/S3/Sportback (8P Chassis)
    Last Post: 4th October 2010, 09:29
  2. Porous cylinder head - coolant loss
    By warren24 in forum A3/S3/Sportback (8P Chassis)
    Last Post: 20th May 2009, 10:38
  3. Coolant pipe with heat shield
    By S3mad in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th August 2008, 21:33
  4. heat shield for coolant pipe >?
    Last Post: 2nd August 2008, 18:56
  5. Coolant pipes
    By Seizure in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th January 2004, 23:10
