Sky InsuranceAH Fabrications
    66
    oil bubbling in sump!!!wtf
    Ok here is one to pick everyone's brain, just done a pressure test from my TIP(with breather blocked off) to test for boost leaks and split vac pipes and only thing that I could hear is oil bubbling in the sump. Immediately I thought that the head had blown between a cylinder and oil port but as I write this I'm thinking it is most likely coming from the oil return pipe in the turbo ie through the turbo seals! Might be a no brainer but like to know what every one else thinks anyway. Don't see really how air could get back down through the block and bubble in the oil with non-return valves in place.
    Thanks, any comments welcome.
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,417
    Is it a 1.8T?
    If so I think the oil pick up could be blocked
    Mike
    May 2012
    RETFORD, NOTTS
    1,707
    How much pressure was used? When I was investigating boost leaks it was advised any more than 5psi could damage seals. Smoke testing draws a 1psi vaccuum iirc. If you think you have a leak would recomend smoke testing, as it picked up my leaks immediatly.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Oil Pick up / sump clean. A 'for reference post'
    By tt ted in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th March 2012, 12:23
  2. Oil leak from boot wtf?
    By S3-Oski in forum A3/S3 Forum (8L Chassis)
    Last Post: 6th June 2009, 20:53
  3. Sump oil level sensor conversion
    By lucksta in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th April 2009, 20:46
  4. Magnetic Drain Sump Oil Plug Help
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 2nd February 2009, 10:54
  5. Sump oil 'Black and thin' 1200 miles after service
    By chimmo in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th March 2004, 18:40
