Sky InsuranceJMB Retrofits
Results 1 to 10 of 10
    Mar 2013
    16
    02 a4 1.8t transmission problem help!
    Hey guys. I just put a new transmission In my 02 a4 1.8t auto transmission code fep not a cvt. The issue I'm having is that it works perfectly fine in reverse and sport mode but when I put it in drive or tip mode my gear indicators turn red. It is full of new fluid all the plugs are hooked up and are clean. It doesn't always go into limp mode usually if I drive it in sport mode then put it in regular drive it won't go into limp mode. I'm so lost any input would be great. And yes it had a fep code transmission in it originally.
    Mar 2013
    16
    Bump
    Jun 2011
    Great Melton Norfolk
    1,349
    Have you scanned the gearbox ecu for fault codes? Was the correct fluid used?
    Mike.M's Avatar
    Oct 2003
    Dorset
    1,571
    As above........plug it in and read the codes
    Mike
    B6 A4 1.9 TDI Sport 130 - GMBH/S-Line kit - Akoya Silver
    - BUILD THREAD >>
    Mar 2013
    16
    Quote Originally Posted by gen.heinz guderian View Post
    Scanned, no codes come up yes the correct fluid was used I used pentosin atf 1 I have no cel's at all. Whenever the gear indicator lights up I just turn the car off then turn it back on and it's not lit up anymore till I put it in regular drive or tip mode..
    Jun 2011
    1,349
    What is the exact gearbox code? Is it 5 spd or 6?
    Mar 2013
    16
    It's 5speed as said in the first post it's code fep I don't know the number under the transmission code tag for sure it's hp-519 I believe
    Jun 2011
    1,349
    a 5h19 ZF autobox is listed for a rwd BMW.
    If you could get the code off the box it would be easier.As far as i am aware there are 3 manufacturers of auto boxes for VW/Audi , Aisin Warner, ZF and Jatco. Parts are readily available for them all.
    Mar 2013
    16
    I haven't had a chance to get the numbers off the transmission yet. But I did replace the transmission computer and it is still going into limp mode when In drive. The car doesn't even need to be running even if I just turn the key to the on position and put it in drive it will go into limp mode. No cel 's at all. Getting annoyed!
    Mar 2013
    16
    And threw our Mac scanner on it to check transmission info and nothing is coming up on that either...
  1. Help! Audi A4 transmission problems when it rains
    By Sunflower in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 16th May 2012, 16:12
  2. MULTITRONIC PROBLEM - HELP
    By JohnBoy in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 21st September 2004, 10:41
  3. S3 Boot problem...help needed...
    By Austin in forum A3/S3 Forum (8L Chassis)
    Last Post: 16th August 2004, 23:39
  4. instument problems, Help
    By fireblade in forum A4/S4 forum(B5 Chassis)
    Last Post: 8th August 2004, 19:11
  5. Transmission Problems
    By MisterD in forum General Technical / How To
    Last Post: 3rd February 2003, 13:23
