Monster MotorsportChris Nott
Results 1 to 7 of 7
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Question All front control arms replaced, front now sitting marginally higher??
    Is this normal? Had all 8 front arms/2 drop links/2 tie rods replaced, and four wheel alignment done......Feels like a new car though
    *WANTED* AUDI CD PLAYER
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    Not sure if it's normal, but good to hear it's much nicer. Mine is driving like a bag of nails at the moment, but I don't think my alignment was done well when I lowered it. I've also considered replacing all control arms etc to renew it all.
    Oct 2012
    436
    where the arms tightened with the car on the ground or on a a drive on ramp?? if not the bushes could be stressing whichmight cause it to sit higher
    mattyb6's Avatar
    Apr 2012
    Tyne & wear
    457
    Dale, how much did you pay for all of the arms? If you don't mind saying.
    mine are due, along with track rod ends and top mounts etc
    03 Mig blue 1.9tdi 130 saloon:- GMBH front, dark tints all round, fk coilovers,
    BMW TIGERCLAWS 19" 9j front + 10j rear, debadged rear. HIDs 6k, egr delete
    cominig soon:- votex rear,front end respray, parrot kit, remap, full paint correction
    AlexGSi2000's Avatar
    Feb 2012
    Liverpool
    1,160
    I was going to suggest what Ian has.
    Mine was the same to be fair - even though it was all tightened when the car was under load.
    2002 A4 Avant Quattro Sport 2.5 V6 TDi - 219Bhp - Votex
    BCS Automotive Turbo-Back - Remap -
    19" RS6 Reps - B6 S4 Brakes - Symphony II+
    - Weitec GT
    - 2001 Honda CBR600-FS1 -
    Oct 2012
    436
    maybe that's how it was from the factory and everything has flopped as it's got older........... ooo errrr missus
    DALE_AVANT's Avatar
    Avantage
    Jan 2012
    442
    Pretty sure the mechanic would've tightened up the correct way. Sitting maybe 10mm higher than I'm used to on the factory Sports suspension, probably is how it should be then?
  1. Replacing One upper front control arm ?
    By audi130 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 24th June 2010, 23:47
  2. front control arm replacement
    By cjrob in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th March 2010, 16:08
  3. front control arm kits
    By livlee1 in forum A4/S4 forum(B5 Chassis)
    Last Post: 29th April 2008, 19:19
  4. 100/A6 Front Suspension Track Control Arms - Replacement
    By deemde in forum Classic Audi Forum
    Last Post: 30th May 2006, 11:12
  5. Upper Front Control Arm
    By imported_Coullio in forum Handling
    Last Post: 2nd July 2005, 20:44
