Volks AutosChris Nott
    Oct 2012
    436
    A4 1.8T coolant leak
    Had the cambelt water pump in dec2012 by audi car now has coolant leak not sure where from but wife says there is a puddle of water under the car i don't have a pressure tester any ideas where these leak from??
    could be the pump is leaking that was the reason for doing the cambelt
    ta
    ian
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Get under the car and try and locate the source. If it does appear to be the water pump then I'd be straight back to audi telling them to put it right as the belt and pump should still be under warranty.
    A4 Avant 1.9 TDi Sport GmbH
    Oct 2012
    77
    Not necessarily the water pump though - could be a split hose or where hoses join or a connection on the radiator. As Audi Doodah says have a look under the car with a good light.
    Oct 2012
    436
    The car is now back at the dealer and i kinda get the feeling that even without looking at it they are building me up for bad news like it's not the pump it's something else
    So the question is what else right on the front of the engine could leak coolant, is there a flange or some other part that i am not thinking about, as far as i can see on etka it's just the pump, those who have replaced a pump may have a better idea
    thanks
    Ian
    Oct 2012
    436
    Well dealer has now replaced the pump said it was faulty but didn't know why when asked odd it's only done 3k miles
    Sep 2012
    Swindon
    371
    No manufacturing process is perfect...wouldn't be cost effective. There will always be a very small percentage of failures expected, something like 0.002% on a mass production line. You just happen to be one of the unlucky ones.
  1. Coolant leak
    By petewon in forum General Technical / How To
    Last Post: 5th October 2006, 21:33
  2. A4 coolant leak
    By spud in forum A4/S4 forum(B5 Chassis)
    Last Post: 4th October 2006, 19:29
  3. Problems with S3, suspect coolant leak & Turbo dump/recirc Valve noise??
    By fasteddie in forum A3/S3 Forum (8L Chassis)
    Last Post: 19th August 2006, 17:17
  4. coolant leak - need to id name of pipe
    By Fraser in forum A4/S4 forum(B5 Chassis)
    Last Post: 11th March 2006, 01:03
  5. Possible coolant leak, any ideas?
    By jgrand in forum A3/S3 Forum (8L Chassis)
    Last Post: 31st August 2005, 11:46
