JMB RetrofitsSky Insurance
Results 1 to 8 of 8
    Dec 2012
    Ashford Kent
    Help needed asap
    We have an Audi A4 1.8 2002 and we cannot get into it because the battery is flat. Has anyone had this problem and managed to get into their car.
    Andy
    Andie0's Avatar
    Aug 2012
    487
    Have you tryed oeping the boot and going through back seats?
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    Andie0's Avatar
    Aug 2012
    487
    From the sounds of things, the previous owner has removed the actuating rod from inside the driver's door lock. This means the only way the driver's door lock will open the car is via the central locking pump itself, using the key or remote, as long as there's power (charged battery).
    So, with a live battery, the car can be unlocked via the OEM key fob, or by double-unlocking the driver's side door, the pump will lift ALL the locks. The operating rod within the driver's side door (linked from the lock cylinder to the door mechanism) is the only mechanical connection. Remove this, and the only means is via double-unlocking, which is electrical, and needs battery power to operate.
    It's the factory deadlock / anti-car jacking function, whereby if you unlock the car via the key on the driver's side, only the driver's door is unlocked, reducing the instance of being car-jacked via the other unlocked doors.
    Best way to gain access is to take a jumper pack under the car, connect the negative clamp to a good ground, and the positive to the permanent live on either the alternator or starter motor. This effectively restores power to the car, allowing the central locking to operate, either via the driver's side lock, or the remote.
    I hope your car isn't stupidly low, and your jack isn't locked in the trunk too...
    My advice, once you gain access to the car, please purchase the driver's side actuating rod, save yourself a bit of grief in the future. Good luck.
    Dec 2012
    Ashford Kent
    Quote Originally Posted by Andie0 View Post
    Thats great, thank you, we will give it a go.
    Mar 2013
    Near Oxford
    404
    that is **** luck, guess the boot is the only way to go.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    If that don't work then hope you have manual windows in the back and a coat hanger towel and a flat strong screw driver to wedge open the door...... had to do this a couple of times and it's a slow process
    Jun 2011
    Great Melton Norfolk
    1,349
    I assume you have tried the key in door?
    May 2012
    RETFORD, NOTTS
    1,753
    Its a shame your not closer, I have some nifty lock picks, assuming you left your key in the car?
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
  1. Brake upgrade help needed ASAP!
    By PTTM in forum A3/S3/Sportback (8P Chassis)
    Last Post: 22nd July 2010, 16:40
  2. HELP NEEDED ASAP!!!
    By supanova in forum A3/S3/Sportback (8P Chassis)
    Last Post: 31st May 2010, 11:24
  3. Adapter help needed ASAP PLEASE
    By ruairi83 in forum A3/S3 Forum (8L Chassis)
    Last Post: 26th May 2010, 00:40
  4. 1.9tdi(110) not revving, help needed ASAP
    By Lex in forum A4/S4 forum(B5 Chassis)
    Last Post: 3rd March 2009, 21:21
  5. Exhaust/Engine Question Help Needed ASAP
    Last Post: 21st January 2009, 17:36
