Sky InsuranceAH Fabrications
Results 1 to 8 of 8
    May 2013
    Bought an A4 but zero key fobs work!
    Hi all
    Last weekend I bought a 2002 A4 Cabriolet in the UK so am finally in the Audi family
    However it only came with one key, which does not work remotely... the previous owner just used the key in the lock... and guessed that perhaps the battery had died. I changed the battery but surprise surprise it still doesn't work. I also tried the 'turn key to on, press lock on fob for a few seconds, press lock on door for a few seconds, then repeat for unlock' as I was advised to try in another forum, and that still didn't work.
    (Apologies if this is covered in other threads. I've mainly seen questions where one key fob has stopped working but the owner still has a spare to program it from... whereas I have nothing that works!)
    Firstly I want to get the first key fob working, and then I want to get a spare made. Will I need to go to a dealer to get the first one working? Or is there another way? I imagine the battery has been flat for many months.
    And would I then be able to buy the right model of key fob (8ZO 837 231 D) from Ebay, get the blade cut, and then program it myself? Or would I need the dealer to do that for me too?
    many thanks
    Ben
    May 2012
    RETFORD, NOTTS
    1,753
    You can do this with VCDS. Where are you based there may be a local VCDS owner to help you out.
    EDIT:
    Sorry, I was on the phone!
    To expand on this, VCDS software will program compatible keyfobs for remote locking etc, and with the use of a pin reader can reprogram new keys. New keys to operate the immobiliser should be new as the chips cannot be reprogrammed to a different car. Key fobs sometimes work for the central locking from another car, but new are quite cheap to buy anyway.
    The map of people with VCDS is here: VCDS (formerly VAG-COM) forum
    You will have to check for somebody local with a pin reader too to be able to program your new key.
    If you are local I will be able to both supply and code a new key, but I am unable to personally cut a new blade.
    '02 TDi 130 Sport: Mods to date: BXP 160 conversion, EGR delete, Decat, Helix SMF fast road clutch, 312mm front rotors, full DIS , CC, Xenons.
    VCDS fully registered and happy to help.
    *Need a Spare Key or Remote? SKC retrieval? Clock/ECU swap or milage correction? I am fully insured to work on your vehicle! Offering a good deal and quality service to ASN members Nationwide!*
    Oct 2012
    434
    or it maybe if the battery has gone flat it needs re synching to the car which does not involve vcds just done this on a friends passat
    crazy88's Avatar
    Loving the anonymity
    West Yorkshire
    4,806
    To program a new key you'll need vcds still, and the skc also. Have you got that? It's a 4/5 digit code that you need to program a new transponder.
    Greeny233's Avatar
    Mar 2011
    Llangollen
    698
    Follow Greeny233 On Twitter Add Greeny233 on Facebook Add Greeny233 on Google+ Visit Greeny233's Youtube Channel Visit Greeny233's Instagram Channel
    What ever you do don't muck about with your key fob, I tried replacing the key fob and transponder and ending up with an immobilised A4 and a bill of £350 from Audi to supply and code new keys and not to mention the £50 to get the car recovered
    If you go to Audi with the key fob you have they can restore it for £45. You should get a replacement key ASAP, I put getting a spare key for mine off and it ended up being a nightmare.
    It'll cost £150 for a complete key, fob ad coding from Audi.
    Chris "the machine" Green.
    2004 Audi A4 1.9tdi Sport Quattro Avant
    crazy88's Avatar
    West Yorkshire
    4,806
    Yeah, if you've only got 1 I wouldn't go messing with that one. Get a replacement first and take it from there.
    May 2012
    RETFORD, NOTTS
    1,753
    My complete key with cut blade and new chip cost under £40 brand new and nothing to code, stuff paying Audi prices! They wanted £170 iirc for my A3 2002.
    The only time you have issues is if you dont do your research, like a guy a short while ago who tried programming a key from another car, and then replaced the chip with the wrong type! The correct chip was a few quid and reprogrammed using vcds and a pin reader.
    gtvlew's Avatar
    Mar 2013
    SWANSEA,WEST
    65
    Both my key fobs stopped working, this is what i done to get them going again, but you do need 2 keys to start with, Help !!!
  1. Key Fob Just Stopped Working Lock/Unlock not working
    By tomgreen78 in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 17th March 2010, 23:53
  2. Remote Window Control from Key FOB - Not Working
    By Hellz in forum A3/S3/Sportback (8P Chassis)
    Last Post: 25th January 2010, 09:32
  3. S3 KEY FOB NOT WORKING!!!!!!
    By MAD HATTER in forum A3/S3 Forum (8L Chassis)
    Last Post: 15th August 2009, 14:54
  4. key fobs stopped working
    By bigblokey0 in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 3rd August 2009, 18:43
  5. Key fob not working
    By S3-James in forum A3/S3 Forum (8L Chassis)
    Last Post: 18th October 2006, 19:15
Tags for this Thread
