Badger5JMB Retrofits
Results 1 to 7 of 7
    Feb 2013
    69
    b6 1.9tdi temp gauge playing up again help
    have new stat done 1000miles or so should i do cts now and does the car have a viscose fan ia the cts hard to fit
    Oct 2009
    Hull
    1,440
    Bit more info would help!
    What's happening with the gauge did you use a gen stat?
    Feb 2013
    69
    going up and down its form local motor factor
    Oct 2009
    Hull
    1,440
    Always replace with gen
    Erratic needle is usually a sign of the sensor
    Audi Doodah's Avatar
    Sep 2012
    Swindon
    371
    Senor is located on the pipe at the back of the engine block on the 1.9, nowhere near the viscous fan. Get an OE one, green, with 4 pins. A simple swap but you will need to top up the coolant after.
    A4 Avant 1.9 TDi Sport GmbH
    Feb 2013
    69
    fitted cts today pig of a job but done will see how long it lasts
    Jul 2012
    Derbyshire
    306
    This was happening on my 1.8t cleaned the connector to the top of the sensor and no more erratic needle it's as though it was a dirty connection might not be on yours but worth a shot
  1. Temp gauge playing up again.
    By lnewland in forum A3/S3 Forum (8L Chassis)
    Last Post: 12th October 2011, 18:18
  2. Temp Gauge on 1.9TDi A4
    By necroeire in forum Diesel forum
    Last Post: 14th July 2006, 15:48
  3. A6 2.5TDI V6 temp gauge falling and rising??
    By imported_Auditurbo in forum A6/S6/Allroad forum (C5 Chassis)
    Last Post: 17th June 2005, 00:44
  4. Help with my Temp Gauge
    By XXX_18T in forum A3/S3 Forum (8L Chassis)
    Last Post: 21st October 2004, 09:53
  5. A3 temp gauge
    By adjturbo in forum A3/S3 Forum (8L Chassis)
    Last Post: 20th October 2003, 19:45
