Results 1 to 9 of 9
    imported_CurryMilkShake
    occasional whiff of diesel
    As title - I am getting an occasional smell of diesel from the car while driving..
    nothing obvious, and no consistency to circumstances so far.. have had it cruising on the motorway, have had it driving hard, have had it pottering, doesnt seem to last long.. but never used to do it at all.. have had it about half a dozen times over the last few weeks, so about 2000 miles.
    Car is fully serviced, done nearly 40k in 17 months.. is remapped, but the remap was done ages ago, this is recent.. no obvious leaks at all.
    any thoughts or do I whip it in to the stealer?
    peteA3tdi's Avatar
    Mar 2004
    the rose and crown
    406
    Re: occasional whiff of diesel
    have a look under the car on the drivers side after a run, theres a fuel cooler (just bendy pipes with a grill to draw air) running front to rear , the return pipe can split and leak a small amount of fuel
    Jul 2004
    co,antrim
    116
    sorry ,haven't noticed the smell of any diesel, but when 3/4 full the sound of it sloshing around in the tank in stop start driving is very irritating . Has anyone had this problem?and had a cure for it?
    Thanks Pete - will check that in daylight tomorrow!!!
    The911SC's Avatar
    Sep 2003
    South Wales - Swansea
    1,032
    [ QUOTE ]
    [/ QUOTE ]
    You should try driving behind you guys in your diesels, you get more than a whiff of that black smog!... [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    technics100's Avatar
    Feb 2004
    Co Antrim
    772
    No Smoke No Poke...............................
    911sc, its a fair comment!
    you have about 60 more HP than me, thats got to equal more fun, and no smoke.. The tradeoff is still easy for me though - I do around 30,000 every year, my employer only pays 9p per mile.. all of a sudden that oil burner seems a lot more appealling, dont it!! life is all about compromises..
    if my car was a weekend fun machine, or I only did 10k, it would be a differnet story..!
    Nov 2004
    St. Albans
    61
    I had this issue. Was more than a whiff. Ended up being a split fuel hose. Cost me 230 to fix :-(
    a4sline's Avatar
    Oct 2004
    land of Strongbow
    185
    Check the plasic drain plug on the bottom of the main fuel filter. Was a 6mm thread that kept snapping, now a 8mm thread and much stronger with no casualties.
    HTH
