Badger5Monster Motorsport
Results 1 to 19 of 19
    Mar 2012
    188
    Lightly modding 1.8t
    Had my A4 for just over a year now. Have been actively renewing and doing general maintenance to make sure that when I wanted up the power a bit it was going to be a reliable base.
    Now I've been researching recaps for a while and have decided on APR for two reasons, switchable maps and the fact that it is a progressive map rather than an aggressive one.
    A few cheaply upgrades that will be going on at the same time are a forge tip, tt225 injectors and also a decat pipe. This means I can go for the stage 2+ map.
    I was wondering if there are any other relatively cheap upgrades I can stick on? Happy with stock filter and exhaust. Should I be looking at 2.0t coil packs and larger gaps on plugs?
    Mar 2012
    188
    Forgot to mention its a BEX so has a twin intercooler setup as standard.
    Mar 2013
    Near Oxford
    405
    Go to r tech and you won't go far wrong. Are the standard intercoolers up to stage 2 maps?
    Mar 2012
    188
    Rtech are too far away plus I want switchable maps.
    Stage two is the limit of the turbo / intercoolers an the apr map. After that its front mount, new turbo and lots of ££££££'s
    Mar 2013
    Near Oxford
    405
    Fair doos, shark can also do switchable maps and have a good rep.
    32
    ihave the 190t and been looking at maps on standard vehicle - r-tech suggested 200-210bhp and around 225lbs whichis an impressive increase (torque and the improvement that suggests in drive as long as it retains 'smooth').
    Can you let me know what you are expcting from the TIP and 225 injectors (are you getting a 2nd hand set off a TT or S3/Leon or otherwise i'd expect even non oem to work out expensive)??
    Andie0's Avatar
    Aug 2012
    487
    You may not be able to go apr as when i enquired and took my car to them for it to be mapped they said there was no map written for our ecu code!! Alot of people like r tech on here but if you want to be able to adjust your map to suit you them go revo as i have and you an use the sps softwareto adjust boost, timing and fueling! Ive had no issues with my map what so ever and it quick as for a stage 2! I got 242bhp on the rollers
    2004 audi a4 s line 1.8t bex 242bhp dynoed
    Mods: bsr optiflow kit, forge diverter valve, custom turbo back exhaust, custom 200 cell cat, DGR coilovers, forge tip, s3/tt 386cc injectors, boost gauge, revo stage 2, 12mm rear spacers, rear window extension spoiler
    To come: big brake setup... Getting there!!
    boats and hoesss, boats and hoesss
    Mar 2012
    188
    Hmmm, so they don't do the bex. Shame, I did question them why the website only had one variation of the 1.8t on it for the B6. Looks like I'll be going to someone else then.
    I got the injectors off eBay using the part no for a TT225, they were £70 for 4. Getting them cleaned, tested and serviced for about £15 an injector.
    Andie0's Avatar
    Aug 2012
    487
    Have a look into revo is a decent bit of mappinggg
    Mar 2012
    188
    Well I've sent my ecu number to APR so they can check there database to see if my car is mappable by them. The 190 engine does show up on the apr Australia website so I am still hopeful.
    Although it looks like the bex 190 engine already has updated injectors compared to the lower bhp models so my TT225 injectors were a waste of a purchase.
    Not sure weather to stick them back on eBay at a loss to get shot are get the refurbed and sell them on then.
    Andie0's Avatar
    Aug 2012
    487
    I have bex engine and needed my injectors as standard ones couldnt cope with fueling! So dont sell them just yet! Just to let you no my firend has a apr map and my revo pulls harder and runs better
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Sport CAT is a good investment and 034 unit will gain you around 12bhp
    Mar 2012
    188
    Re the revo comparison, suggestion is the revo is quite aggressive with the apr smooth. I'm not after a big kick in the back, just a bit more shove.
    Re sports cat. I'm ditching the cat altogether and going for a test pipe.
    Andie0's Avatar
    Aug 2012
    487
    My power is very smooth just have a nice amount there! Even having 250 the audi still feels sluggish for its size needs 300+ to kick you in the back! I also now want to go for a test pipe as think it will benefit massively from this! Mine failed mot with he sports cat anyway so not worth a ****! Will be buying a test pipe also
    Mar 2012
    188
    Thanks for the feedback. How did you know you needed the injectors?
    Mar 2012
    188
    What I mean is did you know you needed them before you had the remap or was it something that came about because of it?
    Andie0's Avatar
    Aug 2012
    487
    I was told by kev at revo that i would need them so i bought some, then when i got to the place to get it mapped the first thing he asked was if i had the injectors he had mapped one 2 days previous which couldnt obtain the fuel needed to run the map so had to send the guy away until he got injectors! I got second hand ones and had them cleaned at a place near me! Ive had no issues since having the map in anyway! None of this power surging as i read quite commonly happens on here with other maps! And to be honest love the fact i can mess about with the map once i fit and remove diff mods!
    Mar 2012
    188
    Thanks. I'll drop revo an email tomorrow to ask about there different stage maps.
    My total hardware will be forge tip, test pipe and the injectors. I may fit a piper panel filter yet. I've already replaced the DV with the updated oem one.
    Andie0's Avatar
    Aug 2012
    487
    Thats all yu need for a stage 2 map, you must get a uprated panel filter though, i have a bsr optiflow kit and works well! People on here say it is pronemto heat soak but it doesnt affect me so far! Have a secondry cold feed running to it so gets plenty cold air
  1. Interior Ambient Light Mod? Where can I find it?
    By Joe90k in forum A3/S3/Sportback (8P Chassis)
    Last Post: 14th June 2009, 12:02
  2. Ambient light mod
    By razza1 in forum General Technical / How To
    Last Post: 27th May 2009, 17:02
  3. Some new pics of the car and Fog Light mod.
    By aragorn in forum A4/S4 forum(B5 Chassis)
    Last Post: 12th January 2009, 13:16
  4. Clear rear light mod
    By stapo69 in forum A4/S4 forum(B5 Chassis)
    Last Post: 6th September 2008, 16:00
  5. Help with door warning light mod
    By justandy in forum A3/S3/Sportback (8P Chassis)
    Last Post: 30th July 2008, 13:28
