JMB RetrofitsVolks Autos
Results 1 to 10 of 10
    Apr 2012
    Unhappy Esp + glow plug + brake warning lights on
    Hi,
    The back brake lights are out on my 03 1.9tdi A4 aand these warning lights are flashing.
    I first tried changing the bulbs. No joy, so I had a look at the fuse and it looked fine.
    I had a read about and a lot of people were saying it's the brake light switch, but the funny thing is my center brake light still works!
    I rang Audi and they confirmed that all 3 brake lights work off the same brake switch.
    I'm a bit baffled now, any ideas??
    TIA
    quattrojames's Avatar
    Mar 2008
    Dorset
    13,856
    I know it makes no sense, but I'd try a switch as I think I've heard of this before.
    Were the bulbs you replaced blown? I'd check the PCB where the bulbs attach to with a multimeter too. It's going to be brake light circuit related somewhere along the line I'm sure.
    Apr 2012
    Thanks, will do!
    deano1978's Avatar
    different gear
    Jan 2013
    near brighton
    634
    I get these issues when i switch headlights on??????
    So turn off and on (engine) then it dosnt happen.
    A4 avant b6.1.9 avf 6 speed. Bv43 turbo.uprated fmic. More bhp custom map. Powerflow straight through twin pipes. Allard delete kit. Boost,egt, + voltage gauges. Ball,spring boost controller. Fk silversport coilovers. 312mm brake upgrade. B7 multifunc steering wheel. Full dis. Cruise control. Auto locks. Rs4 rear bumper. Full rs4 grills. Drls + hids. 10inch custom sub + amp. Rear parking sensors. Leds everywhere. Parrotkit full speaker streaming. silver 4d carbon interior.never ending...
    amz
    Sep 2011
    184
    Quote Originally Posted by deano1978 View Post
    Bump!
    Nov 2010
    206
    I have started to get the same symptoms as above poster, anyone know of any culprits, I have aftermarket hids fitted, from hid direct, if that helps
    B6 A4 Avant 1.8T (190) S-Line
    4th set of a wheels in a year
    Jul 2012
    merthyr, south wales
    432
    Visit krisavant's Instagram Channel
    Bad hids can bring up these dash lights.
    I would have these lights come on all of a sudden, turn engine off, dash lights would go out. Turns out when I would brake, the dash lights would come up again!
    Took hids out, put back to oem, all good.
    My verdict, Hids and the brake switch/servo don't get on..
    Mar 2004
    Leicester UK
    133
    I had all of your symptoms driving along the lights either would be on when not even in use, quick check would be to remove the brake switch from the pedal and see if you can push in the actuator, the one I replaced on mine would not return very well compared to a cheapy one bought from euro car parts £12:00 no problems since I replaced it.
    Sep 2009
    Rumburgh Suffolk
    193
    Had a similar thing with a Landy a while ago.. different car I know, but the brake light switch incorporated 2 switches, one for the brake lights, and one for the ABS / cruise control, the cars ECUs monitored both switches, if they didn't go on and off together it would bring on traction and ABS lights... new switch cured it.
    Mark
    2001 A4 TDI 130 SE, takes me to work
    2011 Suzuki Alto SZ4, tootles the good lady around
    1992 Replica Cobra 4.6V8, makes lots of noise...
    and gives you neck ache, and isn't for sale anymore...
    1949 Ferguson TED20, moves things that I can't move
    1959 Massey Ferguson 35 TVO, thats two ticked off the list...
    Lucky the good lady likes tractors...
    bez101's Avatar
    Yorkshire & Humber Rep.
    Jul 2008
    8,530
    with the break switch gone it will still work the center brake
  1. Replies: 5
    Last Post: 18th February 2013, 00:11
  2. HELP!! ESP GLOW PLUG WARNING LIGHTS ON
    By Arf in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 4th June 2007, 02:47
  3. Brake Warning Light After Brake Pad Change
    By iddyarmin in forum Audi S4/A4/A4 Cab (B7 Chassis)
    Last Post: 28th May 2006, 20:47
  4. Brake warning Light
    By imported_Smudge973 in forum A4/A4 cabriolet/S4 forum(B6 chassis)
    Last Post: 3rd January 2005, 19:17
  5. Intermittent Brake warning light - WEIRD
    By manikm in forum A4/S4 forum(B5 Chassis)
    Last Post: 7th May 2004, 22:20
Tags for this Thread
